Stud/Nut Conversion Sets........
I will soon be able to supply a conversion for RS Turbo's to take them from Bolt configuration to Stud/Nut. This makes it far easier when swapping wheels etc.
This consists of :-
16 Studs, which are slightly longer than normal which will allow for a Spacer if needed, but are fine without. These studs will require drilling of the original Bolt Holes to allow the new Studs to be pressed in.
16 Nuts. These are Chrome, Dome-topped Nuts, which have 19mm heads and are quite nice looking.
The cost will be about £29.99 inc VAT and Postage.
I can sustitute 4 of the Studs/Nuts with a set of Top Quality lockers for an extra £25. (£54.99 Total).
Would that be interesting to anyone??
It is the same conversion that I have on mine.
I can get simple conversion studs, which just screw into the original thread, leaving a stud, but I wouldn't recommend these for the sort of application that we are concerned with!!
This consists of :-
Deffo put me down for a set christian .
U say longer , how much longer , i think i run 10mm longer bolts at the mo so i can fit my Gpa rims , will these still alow me to run the Gp a rims ????
13mm longer.........
I can do them longer still if needed. Alternatively, these studs can be cut down, but they won't need to be.
When we did mine, we removed the hubs completely and drilled them out and simply hammered the studs in. Was really quite easy.
Cheers christian , can u get me a set @ 25mm longer please , i can always cut them if needs be ,
another thought could you get a set of nuts that are straight through ie not domed .
Dunno who your supplier is but if u ask them for a GP a stud and nut kit im sure theyll give you what u need .
I'd be interested.
The head of the stud at the back of the hub, do you know what height it would be?
(hope that makes sence)
I have Traction sensors on mine and need to make sure they won't fail.
Thanks
Thanks
Don't suppose you've got some piccys of your stud conversion ?
Will i be able to retain my current alloys ?
I'm very interested BTW
OK Guys. To do this conversion properly, you need to remove all the hubs, drill the original Bolt Holes out to allow the new studs to be a tight press fit (from the back of the hub). The shank of the Stud is splined. It can be done with the hubs on the car, but its not really worth it as its not hard to remove the hubs. The studs MUST be knocked fully in, otherwise your wheel tightening torques may be affected. In any case, they must be checked a couple of times after a few miles, as you normally would.
This conversion is the BEST way to do it. As I said above, I can do some other conversion studs that simply screw in, if anyone wants to do it the easy way, but I wouldn't recommend it.
I'm afraid I don't have any piccies, but it looks factory once its done properly.
As for the height of the head of the Stud, I dont have a stud handy, but I think its around 5-8mm.
The Studs are 13mm Longer than a Standard Ford Stud, this will be fine on a Standard Car, because the nuts are deep enough to take it. The studs can be supplied longer if needed or indeed cut down if you want them shorter.
Hope this helps.
For those that are interested, I will need to know exactly what you want so I can get it all ordered. So far, there is interest from :-
Gus - 16 Studs / 16 Blue Nuts - PAID - POSTED 23/02/05
Lee @ Fusion - 32 Studs / 16 Open Nuts / 16 Closed Nuts PAID - SEND BY COURIER 24/02/05
Sketch - 16 Studs / 12 Nuts / 4 Lockers - PAID - POSTED 23/02/05
cliff6732000 - 16 Studs / 12 Nuts / 4 Lockers - PAID - POSTED 23/02/05
zvhturbo - 16 Studs / 16 Internal Hex Nuts - PAID - POSTED 23/02/05
BlackRS - 16 Studs / 12 Nuts / 4 Lockers - PAID - POSTED 23/02/05
DazC - 16 Long Studs / 16 Open Nuts / 4 Lockers - PAID - POSTED 23/02/05
bassy g - 16 Studs / 16 Nuts - PAID - POSTED 23/02/05
Please let me know if this is not correct.
Hope this helps.
Originally Posted by zvhturbo
Would be just 16 studs for me Christian.
My alloys require special nuts which i can get from the wheel manufactuer.
Matt.
Matt.
They are made by BSA (i think)
Yeah they use an allan key type socket.
Originally Posted by blackRS
Are the lockers studs or nuts ?
Have been thinking about this for a while and was going to make something up myself.
Well there is no point in reinventing the wheel so I will have a set if you can you get open nuts? I have a couple of sets of wheels which need different length studs...
16 studs
16 nuts
4 lockers..
Thank you please.
16 studs
16 nuts
4 lockers..
Thank you please.
Daz, I can do this with many different kinds of nuts even COLOURED ONES!!, will post the alternatives tomorrow. Would rather stick mainly to the ones that I know, but I can sort you some Open nuts no worries.
Having said all that, the Nuts are fairly deep and won't be any more restrictive than the lockers, which are unavoidably closed head.
Lemme know what you think.
Just to clarify, for the above price, I can supply EITHER 60° Taper Chrome Closed-Head Nuts or 60° Taper Zinc-Plated Open-Head Nuts or 60° Taper Internal Hex Nuts. Same goes for Lockers. Standard ERST Wheels and most aftermarket wheels use a 60° Taper. If you are in any doubt, either tell me what Wheels you have or contact the supplier of them to check.
I can supply the 'Ghia' Type nuts that are used on some of the Ford Wheels (such as 7-Spokes), where they have a loose washer. But these are more expensive.
I will get these ordered early next week, so will need you all to cough up over the weekend, if thats OK.
Debit Card payment is favourite.
it would be the only way i could order as i only have a shitty electron card
Yes, to the address on the Website.
And make it payable to 'APT'.
Thanks.
Everyone else, the only thing stopping this is getting the payments sorted, so can you all send me an email to christianbeccy@hotmail.com with your Payment/Address details and a contact number and I will get it moving.
Thanks.
hi mate,i got the postal orders today and im filling them out now and ill send it first thing tommorow when i pick up a stamp
sorry bout having to be awkward with the p.o and stuff.
t\it should be with you within a few days
sorry bout having to be awkward with the p.o and stuff.t\it should be with you within a few days
Originally Posted by Sketch
E-mail sent
Anyone fancy some BLING?? I can get Pukka Lightweight Aluminium Nuts too. They are a bit more money though. LOL.
