Petrol Smell
Old Apr 7, 2011 | 08:26 PM
chrisa3's Avatar
chrisa3
Default Petrol Smell
My 2wd cossie has been smelling of petrol lately. I have checked all the fuel lines on cant find anything. It did have a petrol leak from the pipe between the tank and pump a while back, buts its definately not leaking from there anymore.
Seems at its worst when going round bends. there is a tiny bit of petrol coming out of the breather pipe but given as this is at the rear and you can smell it when moving i cant see it being that. Ive heard people mention injector seals, but wouldnt they show as a leak...
Old Apr 8, 2011 | 09:02 PM
martysmartie's Avatar
martysmartie
I have a slight wiff at the moment as well (The car that is ) in between the reg and the rail there is a tiny piece of hose, this is a crazy design and is very dangerous, it's prone to splitting and if it sprays the fuel in the wrong direction you can imagine the results, so this should be checked as a precautionary measure at least!
Yes O rings should leak if perished, again important as a member on heres car went up in flames due to one going, it was a Westfield with a YB.
Escos/4x4 were revised and have a far better design where the reg is screwed to the rail.
Martin
Old Apr 8, 2011 | 11:11 PM
chrisa3's Avatar
chrisa3
Martin
Yeh, I have changed that pipe and fitted new clamps and new regulator. My exhaust is blowing a little from the rear section, so im wondering if its related to that. Checked and double checked all the pipes and even the injectors are not showing any signs of leaking. Just gonna keep an eye on it.
Old Apr 8, 2011 | 11:31 PM
cosy trav's Avatar
cosy trav
I had a split in my pipe , changed it to a 4x4 fuel rail as it was pissing petrol over the dizzy , how the hell it didnt go up in flames is beyond me . Very bad design on fords part .
Old Apr 8, 2011 | 11:41 PM
chrisa3's Avatar
chrisa3
Are the 4x4 rails a straight swap
Old Apr 8, 2011 | 11:48 PM
Mike1's Avatar
Mike1
Martin
That little piece of pipe used to have a specific finis code - was really reinforced
Old Apr 9, 2011 | 07:07 PM
The pipe between the reg and rail on the 2wd can perish, like any pipe, and especially when 20+ years old, these can be replaced cheaply for well under Ł1 with some 8mm OPA, the original size was 7.92mm!!, but 8mm is fine.
I don't think the change to the 4wd type was anything to do with safety, but more likely aesthetics, and I would say the 4wd one is better, I know which one is easier to check the rail pressure on for the average diy'er, it may have been changed due to commonality of parts thing with other cars, if ford were on the ball they could easily have fitted a shrader valve so the pressure could have been check easy, but they didn't.
Old Apr 9, 2011 | 07:11 PM
cosy trav's Avatar
cosy trav
I had a 4x4 plenum and changed it all over including the 4x4 rail and reg , it isnt a straight swap as the mounting lugs are in a different place but you can make little brackets if needed to mount them i suppose .
timsrs
Nov 13, 2018 11:48 AM
TPM961
Jan 15, 2018 10:50 AM
mk1turboestate
Dec 2, 2015 08:31 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Brickhouse
Sep 21, 2015 04:31 PM
