FAO Of All L8 ECU Owners that do NOT have it mounted in a 4x4 Sapphire.
Old Apr 5, 2011 | 09:27 AM
Stu @ M Developments's Avatar
PassionFords Creator
Default FAO Of All L8 ECU Owners that do NOT have it mounted in a 4x4 Sapphire.
We have developed a new item for you that we think you will like.
It is a bracket to secure the L8 in your car properly the same way the L6 was, with screws. It essentially converts your L8 case to have the L6 wings on it.
As any of you who have converted a L1 or L6 ECU to L8 will know, the ECU ends up flailing around loose as it doesnt mount into the standard L1 and L6 mountings properly due to having no side lugs, well this item fixes that problems. It is also usefull to any owners with the L8 that wish to mount them to a flat surface properly, IE: MK2 escorts, RS Turbos etc.
I am organising a group buy on these to try and get my initial investment back quickly, so if your interested, get yourselves over to teh group buy forum right away.
Click me to visit the group buy topic:
Old Apr 6, 2011 | 10:59 PM
hitchwest's Avatar
hitchwest
Can it be fitted without taking the dash out Stu ? If so one will be purchased
Old Apr 7, 2011 | 07:32 AM
James @ M Developments.'s Avatar
Yes, it mounts to your ECU basically allowing a L8 or P8 to be fitted like the L1 or L6 was with screws
162
Dec 25, 2019 09:43 PM
big_Rad
Sep 15, 2017 09:36 AM
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
41
Aug 21, 2015 06:47 AM
