Split turbo/downpipe gasket?
Old Mar 20, 2011 | 06:14 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default Split turbo/downpipe gasket?
I have a split in my gasket from turbo to downpipe/exhaust. What symptoms would this give?
Old Mar 20, 2011 | 09:44 PM
Camel Fiddler
Would this cause turbo boost issues or a misfiring?
Old Mar 21, 2011 | 01:39 PM
Camel Fiddler
Anyone?
Old Mar 23, 2011 | 05:23 PM
Camel Fiddler
Nobody??
Old Mar 23, 2011 | 05:42 PM
JonathanJ's Avatar
JonathanJ
If it is on the outlet side which is what it sounds like then apart from an exhaust blow it should not cause anything unless it is equipped with lambda then you will find that the mixture will richen up as oxygen is getting in and causing the sensor to see a lean mixture and this could cause issues , should not change boost level unless the system is seeing a weak mixture and turning boost back to prevent damage .
Old Mar 23, 2011 | 06:04 PM
Camel Fiddler
Yeah I have a lambda right after the turbo on the elbow and the car Smells like it's running rich. It has a decat but no EML on and unplugging the lambda doesn't bring it on neither :s
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 23, 2015 06:28 AM
