Zetec turbo owners.....
Old Mar 2, 2011 | 07:37 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default Zetec turbo owners.....
Which plugs are best?
I have a 1.8 16v zetec turbo running T25 turbo and about 190bhp. When I bought the car, I replaced the plugs with NGK platinums for a standard 1.8 which I had been told were correct but I have a stutter on boost and I'm just wondering if the car is able to ignite the mixture correctly or if the spark is getting blown out. Gaps are about 0.7mm iirc
Should I be running FRS plugs or any others, or are the plugs I have fine?
Old Mar 3, 2011 | 07:21 PM
Camel Fiddler
Anyone??
Old Mar 3, 2011 | 08:38 PM
frsjon's Avatar
frsjon
if your car was a 2.0 id say standard focus rs ones..but not sure if they are ok in a 1.8
Old Mar 3, 2011 | 08:51 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'd have thought the FRS ones would be fine.
try closing the gap on the nkg ones first, say down to 0.6mm.
Old Mar 4, 2011 | 12:43 PM
Sp3no's Avatar
Sp3no
You need to run the plugs for turbo charged applicationn, the temperature range of standard 1.8 plugs are all wrong for forced induction. RS ones will be fine
Old Mar 4, 2011 | 06:00 PM
Camel Fiddler
So I'd be right that it could be the plugs causing the misfiring? It does seem worse when I have 95ron fuel rather than 97+ron which makes me think it's ignition related.
Old Mar 4, 2011 | 07:03 PM
woolford's Avatar
woolford
Try 99 Ron and see how it runs
Old Mar 4, 2011 | 08:48 PM
nevsrevs's Avatar
nevsrevs
get some frs plugs as said above heat rating ill be wrong. run at 6.5 on new plugs, and all ways on 97ron or above
Old Mar 17, 2011 | 01:11 PM
Camel Fiddler
Got some Denso 22s in now and car drives alot better but still has hesitation around 3000rpm to now 3750rpm on heavy throttle. Now being run on minimum 97ron all the time- normally sainsburys as it's 131.9 locally compared to local v-power of 136.9 or more. Anything I can be checking before taking it to a a garage? Breather system is clogged but I'll be removing old hoses and replacing with silicon ones to my catch tank tomorrow. Should there be a 1-way valve on crankcase breather port to catch tank? Also my fuel vapor canister has no vac line connected to inlet mani and I know FRS has one with 1-way valve on.
Old Mar 18, 2011 | 04:49 PM
Camel Fiddler
I've got a leak in the gasket between turbo and exhaust mani it seems too. Only when cold there is a little oil comes out the joint but also seems to have an exhaust leak too. I've done breather system and cleaned it all out so car idles better now and has brand new FRS plugs in. What symptoms would gasket leak cause?
Old Mar 18, 2011 | 05:08 PM
Sp3no's Avatar
Sp3no
There should be no oil leak between exhaust and turbo, only if turbo is leaking into exhaust housing and if it is do not use the car till its fixed. Whip the turbo off and check for play in the shaft, you losing oil? Any blue smoke?
Sounds like a catalouge of errors going on, out of the few T series focus's i have seen now they all look like they had been hacked about a bit under the bonnet. Sounds to me like your left fixing the previous owners bodges?
I would literally start from scratch and make sure EVERYthing is working correctly/leak free
Old Mar 18, 2011 | 06:45 PM
Camel Fiddler
Using no oil and no blue smoke I've seen. The smoke from under the bonnet making me think exhaust leak was black but there is a burning oil smell
Old Mar 18, 2011 | 08:13 PM
nevsrevs's Avatar
nevsrevs
you will some times get a bit of leak between turbo flange and mani when cold, but not with lots of oil? check that all your pipes are ok i.e. to map sensors ect.
Old Mar 18, 2011 | 10:14 PM
Camel Fiddler
It wasn't alot no. It just seemed to seep out, increasing as revs did. I'm just currently checking sensors over. Just not sure how to go about it though
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
