EFI Turbo. No spark
Old Mar 2, 2011 | 04:58 PM
nick8saff's Avatar
nick8saff
Default EFI Turbo. No spark
Been asked to look at a mates escort cab with a fiesta turbo engine in. Car wont start because there is no spark but there is fuel. Believe he has put new plugs and leads in it but thats all. At a guess id say one of the sensors but is there anything else i should be looking at thats common. Is there anyway of checking sensors with a multi meter and what sort of readings should i expect to see. Any help would be much appreciated.
Old Mar 2, 2011 | 05:33 PM
JonathanJ's Avatar
JonathanJ
Check if rev counter moves whilst cranking , if not check crank sensor and its wiring , they get hot from proximity of turbo and contacts break down , pm me if you like , look at my location
Old Mar 2, 2011 | 05:39 PM
richard caine's Avatar
richard caine
rs enthusiast
check that the plug to the coil pack has all the wires attached, they become brittle and crack. had the same problem on my car and it took me ages trying to find it.
Old Mar 2, 2011 | 05:48 PM
martysmartie's Avatar
martysmartie
As above I think CPS may be ok as you have fuel but check anyway as said, I personally would think coil pack wiring, check it has power.
You really need an oscilloscope to check the CPS, it gives an AC voltage, the ECU sees the output in a wave format which is what should be seen on an oscilloscope.
Martin
Old Mar 2, 2011 | 06:55 PM
nick8saff's Avatar
nick8saff
Martin
Have only been told its getting fuel so will check the coil pack wiring and cps first. Apparently its been to a garage and they couldnt fix it.
Thanks all
Old Mar 2, 2011 | 06:57 PM
nick8saff's Avatar
nick8saff
Thanks mate will have a look the weekend but nice to know iv got people i can talk to and try and sort it.
Old Mar 2, 2011 | 07:21 PM
MiniLandy's Avatar
MiniLandy
It's getting no spark at all??
I'd get a multimeter on the wiring to the coilpack, then if that's fine, try another coilpack.
If it's not that, then another CPS.
If not that, then your mate's wallet will burst into tears.
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
dms04
Sep 11, 2015 01:57 PM
imnoteasy
Sep 7, 2015 09:26 PM
