Creating new cossie engine loom
Old Feb 18, 2011 | 04:35 PM
5tox's Avatar
5tox
Question Creating new cossie engine loom
I fear that my engine loom is getting a little bit tired so was thinking of creating my own new fresh loom
i saw a kit on fleebay with all the connectors and was just going to make one myself using electrical wire from a local shop, i was wondering if anyone has attempted this before and if its something worth doing?
does it have to be a certain ampage? im really not very clued up on electronics
Old Feb 18, 2011 | 04:40 PM
The Youth.'s Avatar
The Youth.
be vary carfull, some of the wiring shielded to protect it from interference (think the crank and phase sensor wires and poss others) so you cannot just use any wire or you could have all sorts of problems
steve
Old Feb 18, 2011 | 05:10 PM
killa_paul's Avatar
killa_paul
Default re
not something i would try yourself if you have never done any wiring before ,
id recommend getting one done by ....
ryan car looms
07919 537128
Old Feb 18, 2011 | 05:27 PM
5tox's Avatar
5tox
ill get a few quotes but quite fancied creating one myself, would be much cheaper too
Seen a few people create their own looms online, one guy inparticular created a new loom for his 20 year old mercedes...
... then again i also come acrost a video on youtube of a cossie on fire, is it an OMEN? i hope not
had a mate create a loom for a supercharged vw jetta, might see how that goes first
Old Feb 18, 2011 | 05:45 PM
JonnyBravo's Avatar
JonnyBravo
If your not clued up on electrics its probably not something I would advise doing.
It needs to be right or you will end up with a very troublesome running engine.
I'd stick with what you have or give Ryan a call.
Old Feb 18, 2011 | 06:30 PM
AndyPen's Avatar
AndyPen
Ryan is tops!!!
It takes a lot more work than you could ever imagine. I did my three dr bit by bit by stripping the original tape and fixing wherever needed.
Old Feb 19, 2011 | 07:17 AM
Sta1n1's Avatar
Sta1n1
does this ryan have a mail adress where I can reach him ?
Old Feb 19, 2011 | 10:14 AM
JonnyBravo's Avatar
JonnyBravo
carloomsuk@hotmail.com should work fine.
Old Feb 19, 2011 | 03:33 PM
It's easy if you know what you are doing, like all things really.
Good advice above though don't diy unless totally confident, there 's only a few wires need shielding, this is due to proximity reasons to high voltages(ht leads).
The best wire to use is type 44, the guy I use has been doing these before most on here were born, and gives a lifetime warranty on all his looms, has made in all forms of motorsport inc F1 where Ferrari even x ray the connections!!
He;s made some very "radical" looms as well, he does mostly TVR, as the insulation is the favourite "treat" of mice who chew through it on a seriously regular basis on tvr cars.
And tvr's are the biggest pita to fit looms into!!
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
