steering column repair
Old Feb 9, 2011 | 09:09 PM
stevealien's Avatar
stevealien
10 Year Member
Default steering column repair
hey peoples
got up and down play in my steering solumn
noticed a plastic grey round bearing thingy breaking up and falling into footwell.
ive bought a column repair kit which consists of 2 grey plastic rings.
they go at the bottom of the column,just by the mount i think.
if you understand what the hell im on about,
how easy is it to fit them?
do i have to remove column and fit from top or bottom or what?
cheers chaps
steve
Old Feb 10, 2011 | 09:55 AM
CarParts Express's Avatar
CarParts Express
http://www.carpartsexpress.co.uk/RS-...9-225-740-464/
Bearing kit at bottom of list
Old Feb 10, 2011 | 10:12 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Originally Posted by CarParts Express
hmmm, take the stering wheel off and have a look, nothing complicated about any of it mate
Old Feb 10, 2011 | 10:48 AM
stevealien's Avatar
stevealien
10 Year Member
thanks but I've already got the kit. Lol.
Just wondering how simple it is to fit.
Old Feb 10, 2011 | 11:03 AM
stevealien's Avatar
stevealien
10 Year Member
was hopin for a bit more detailed advice lol.
But thanks anyway
Old Feb 10, 2011 | 11:09 AM
javierant3's Avatar
javierant3
Repaired mine about a month ago or so. It`s not very difficult. You have to take out from the car the column. Once you have it out you have to take out the internal shaft. Once the shaft is out you change the two plastic bearings with care to put in the same position as the old ones. The upper plastic bearing has a locating tab in one side that engages in the external bar of the column.Put a little grease between the new bearings.
With all mounted refit the column to the car and you are done.
Old Feb 10, 2011 | 12:58 PM
dazrsturbo's Avatar
dazrsturbo
good advise as im looking to repair mine soon too
Old Feb 10, 2011 | 01:03 PM
Rob_DOHC's Avatar
Rob_DOHC
Fancy taking some pics steve? i'm refitting my column this weekend and im not sure i have all the bits .
Rob,
Old Feb 10, 2011 | 01:16 PM
CarParts Express
sorry didnt spot u had already got
Old Feb 10, 2011 | 01:46 PM
stevealien's Avatar
stevealien
10 Year Member
Rob,
I will rob but prob not doing it till Sunday mate.
Old Feb 10, 2011 | 01:48 PM
stevealien's Avatar
stevealien
10 Year Member
cheers for the useful advice fella
Old Feb 10, 2011 | 04:11 PM
Rob_DOHC's Avatar
Rob_DOHC
Cheers mate , just where it mounts, think i am missing a washer for one of the two lugs that locate the column on the bulk head bracket....
As above, they come apart pretty easily, i bought a kit and replaced all the bushes in the column whilst it was out the car as i had lots of movement.
Rob,
Old Feb 22, 2011 | 07:13 PM
white2lsr's Avatar
white2lsr
Would it be possible to do the repair without seperating the column from the rack? Does the outer tube slide up and off the shaft once the steering wheel is removed?
Old Feb 22, 2011 | 07:20 PM
ROB7656's Avatar
ROB7656
easy to do, just make sure its lined up before you tighten the steering wheel, or you will squash the plastic bearings
Old Feb 22, 2011 | 07:30 PM
stevealien's Avatar
stevealien
10 Year Member
you have to slide outer column up and off the inner column,its the only way as you have to slide bearings over and back down .
when you re-assemble,theres a plastic tag on the upper bearing that locates in a slot.
hold it in place whilst you gently tighten steering wheel lock nut.
be carefull and make sure its alligned.
very easy job once you start mate
Last edited by stevealien; Feb 22, 2011 at 07:38 PM. Reason: too much red wine lol
Old Feb 22, 2011 | 07:34 PM
white2lsr's Avatar
white2lsr
you have to slide column up and off the rack,its the only way as you have to slide bearings over and back down .
But surely you dont need to seperate it from the Rack? From what I can see the outer black tube slides off the inner column.
Old Feb 22, 2011 | 07:36 PM
stevealien's Avatar
stevealien
10 Year Member
sorry thats what i meant.
slide the outer column off the inner lol
been on the red wine mate
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
