FORD FOCUS MK1 1998 1.8i-16v Zetec Problem
Old Jan 31, 2011 | 12:57 PM
walk911's Avatar
walk911
Question FORD FOCUS MK1 1998 1.8i-16v Zetec Problem
Hi Passion Ford, When i drive my focus the Speed O Meter stops working and the car pulls back slightly and loses power and if you stop at traffic lights it will loose rev's and stall most times. Some times Speed O Meter starts working again and speed picks back up, not shure what the problem is or what might need changing.
Could you help me Passion Ford Crew
Thanks
Old Jan 31, 2011 | 01:04 PM
chaffe's Avatar
chaffe
Turbocharging Technician
could be a million things, take it to a reputable Engine managment specialist
Old Jan 31, 2011 | 01:07 PM
walk911's Avatar
walk911
How did i know someone was going to say that, i will wait for another suggestion. Thanks any way
Old Jan 31, 2011 | 01:11 PM
chaffe's Avatar
chaffe
just trying to help, as no one will be able to diagnose your fault without having a look at the vehicle concerned, especially with this type of fault. I could blab stuff like, have you checked the speed sensor and wiring in the gearbox, and have you made sure the ecu and dash is plugged in and getting a good connection, but that wont nesesarily help.
Old Jan 31, 2011 | 01:14 PM
walk911's Avatar
walk911
Hey Thanks Chaffe, It could because its comes on and off just wanted to check some stuff beford taking that road.
but thanks that great
Respect
Old Jan 31, 2011 | 01:15 PM
martysmartie's Avatar
martysmartie
I suspect the VSS, to confirm simply drive at around 10MPH and drop into neutral AND release the clutch the revs should raise to around 1400RPM, if the revs don't raise this confirms the VSS to be faulty.
Martin
Old Jan 31, 2011 | 01:17 PM
walk911's Avatar
walk911
ok im going to try that right now, will let you know how it goes martin
Old Jan 31, 2011 | 01:18 PM
craig_southampton's Avatar
craig_southampton
hi its the speed senor in the gear box easy cheap fix.
Old Jan 31, 2011 | 01:32 PM
walk911's Avatar
walk911
ok, just tried it, drived to 10mph, put car into neutral and released clutch. revs whent up to 12-1300 rpm..
Old Jan 31, 2011 | 01:33 PM
walk911's Avatar
walk911
Thanks Craig i did think it was speedo sensor, effecting the ECU box
Old Jan 31, 2011 | 02:30 PM
craig_southampton
very common promblom on the focus. Thats my bet what it is anyway.
Old Jan 31, 2011 | 03:00 PM
RichieST's Avatar
RichieST
VSS in the gearbox is a very common failure on the focus and it gives the same symptoms you describe, that would be my bet!
Old Jan 31, 2011 | 03:02 PM
walk911's Avatar
walk911
VSS? Could you tell me what that is sorry never hear the name before, sorry got it Speedo Sensor
Old Jan 31, 2011 | 04:31 PM
martysmartie
VSS= Vehicle Speed Sensor
Martin
Old Jan 31, 2011 | 04:59 PM
dannymc86rscab's Avatar
dannymc86rscab
just to throw something else in here... possibly idle speed control valve?? i know that this was a common problem on the earlier zetecs and also the 1.3 ohv engines on KA's and fiestas!! might not be but may help if its not the vss?!
Old Feb 6, 2011 | 12:26 AM
walk911's Avatar
walk911
thanks alot for your help everyone
Old Feb 6, 2011 | 09:46 AM
martysmartie
Have you got it sorted yet?
Martin
Old Feb 6, 2011 | 09:50 AM
walk911's Avatar
walk911
Hi Martymsartie,
Im buying a speedo sensor next week and if it still giving problems will buy the Idle control valve too....
Old Feb 6, 2011 | 10:04 AM
martysmartie
Also defo VSS I should think, patience is a virtue when replacing as they can be very tight (So I have heard), ISCV won't effect speedometer
Martin
Old Feb 6, 2011 | 10:10 AM
walk911's Avatar
walk911
Oh ok Marty, ok i will just do speedo, rev dont fall below 1000rpm when coming to a stop all the time i have notice.
i will follow yours, Craigs and RichieST's advice, and by speedo sensor first....and i will post the results...
Thanks to everyone
Old Mar 15, 2011 | 04:39 PM
user 628729's Avatar
user 628729
I had the exact same symptoms. A new VSS fixed it.
Old Aug 5, 2012 | 06:35 PM
tombo1979's Avatar
tombo1979
yep its the speed sensor my mate done mine hard to get the pin out theres a vid on youtube how to do it now runs fine
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
