Breather system (5 port)
Old Jan 30, 2011 | 01:49 PM
BRAMMER's Avatar
BRAMMER
Default Breather system (5 port)
Just sorting the breather system out and need a little advice regarding the port that goes from the separator to the turbo side of the block instead of the rocker cover.
I have a -10 fitting on the separator fitted with a -10 to -8 reducer down to the block - this is where i need help what is the thread size of the hole in the block turbo side?
Old Jan 30, 2011 | 03:35 PM
B13 JUS's Avatar
B13 JUS
i would'nt reduce the port to -8, i would keep it at -10.
use the reducer for the oil return to the sump, so you will need a -8 on your sump.
thats how i had it i still have the fitting on my engine but not sure what the thread size is but i can measure it for you.
Old Jan 30, 2011 | 03:57 PM
wes's Avatar
wes
3/8" BSP is the thread size on the exhaust side of the block, under the water drain bolt (which is the same thread size too).
As said keep the hose -10 on that side, so you need a 3/8" bsp to -10 jic adapter.
Old Jan 30, 2011 | 04:05 PM
B13 JUS's Avatar
B13 JUS
i think 3/8"bsp is a bit small mate, it measures 16.9mm or 0.66"
one of ebay says its 5/8"
http://cgi.ebay.co.uk/cosworth-breat...item336050f50c
Old Jan 30, 2011 | 04:09 PM
BRAMMER's Avatar
BRAMMER
Justin what you have described there is not using the ex side block return at all and plumbing straight to the sump which if i were doing that i would keep it at -10 from separator to sump but i was going to go from separator to ex side of the block i didn't think i could redue straight from -10 to -3 are your saying fit 2 of the ports into the sump?
Cheers for that Wes
Old Jan 30, 2011 | 04:18 PM
BRAMMER's Avatar
BRAMMER
Just remembered i had a fitting in another block i just measured and thats 16.5mm = 3/8
That size on the fitting mate is 5/8 ID of the hose
Old Jan 30, 2011 | 04:21 PM
jon@work's Avatar
jon@work
the thread in the block on the turbo side is 3/8 NPT, not BSP
Old Jan 30, 2011 | 04:24 PM
B13 JUS's Avatar
B13 JUS
Cheers for that Wes
no mate you have misunderstood me.
your drawing is correct how to pipe the breather system up, but dont use the reducer on the seperator, keep it at -10. so you need an -10 fitting for the block not a -8 how you had it
Old Jan 30, 2011 | 04:26 PM
B13 JUS's Avatar
B13 JUS
i also said put the reducer onto the bottom of the seperator so you can have a -8 return instead of a -10
Old Jan 30, 2011 | 04:43 PM
BRAMMER's Avatar
BRAMMER
Cheers Jon
So this is the fitting (AN-10) 7/8 JIC x 3/8 NPT
http://www.hosefit.co.uk/catalog/pro...30f59c870b947b
i also said put the reducer onto the bottom of the separator so you can have a -8 return instead of a -10
Justin i'm going to run one of thos fitting from the exhaust side of the block (AN-10) 7/8 JIC x 3/8 NPT then run all 4x AN-10 and the 1x AN-12 from the separator.
Thats it sorted -
But just curious as to why you would run -8 on the return as opposed to -10 that is fitted already?
Old Jan 30, 2011 | 04:46 PM
wes's Avatar
wes
No it IS 3/8 BSP:
This is the tap I bought and used to clean the threads on that opening!
Old Jan 30, 2011 | 04:52 PM
B13 JUS's Avatar
B13 JUS
Cheers Jon
Thats it sorted -
yeah there's no problem running a -10 as your return
most people use -8 and i thought if you used your reducer you already had on the bottom of your seperator it would save you money on fittings & hose because -10 are more expensive.
Old Jan 30, 2011 | 04:53 PM
B13 JUS's Avatar
B13 JUS
No it IS 3/8 BSP:
ah i see
Old Jan 30, 2011 | 05:15 PM
wes's Avatar
wes
You want a 3/8bsp fitting and a dowety (sp?) / bonded seal, metal washer with a rubber seal in the middle
Old Jan 30, 2011 | 05:34 PM
BRAMMER's Avatar
BRAMMER
No it IS 3/8 BSP:
Just had a mate text to say it NTP so i'll go with that - not sure regarding the size you used, whats the difference between 3/8 BSP & 3/8 NTP???
No probs mate i have some spare AN-10 stuff here and weld in fittings etc so will just go with -10 return
So this is it then
Old Jan 30, 2011 | 07:49 PM
B13 JUS's Avatar
B13 JUS
So this is it then
thats looks spot on mate
Old Jan 30, 2011 | 08:18 PM
col93saphcos's Avatar
col93saphcos
very little difference between npt and bspt,both tapered,
bsp is parallel,
i think its a tapered thread at that fitting below turbo,
unsure what thread it is tho
bsp/bspt means british standard pipe/british standard pipe tapered
npt means national pipe tapered(used to be more an american size maybe still is)
colin
Old Jan 30, 2011 | 08:31 PM
wes's Avatar
wes
NPT is a tapered thread (National Pipe Thread Tapered Thread), used in the US. The fitting will "crush" into the thread to seal, and you'll need to use PTFE tape to make sure it doesn't leak, not ideal if you ever need to take the fitting out as you'll probably get bits of ptfe tape falling into your sump. A 3/8 NPT thread has 18 tpi (turns per inch)
BSP (British Standard Pipe Parallel) is not tapered (BSPT is tapered). A 3/8 bsp fitting is 19 turns per inch.
The thread in the block is not tapered, which is why i said it was 3/8 bsp.
Food for thought: The pinto engine was built by Ford Europe, not Ford USA...
Old Jan 30, 2011 | 08:51 PM
BRAMMER's Avatar
BRAMMER
Interesting
Old Jan 30, 2011 | 09:18 PM
jon@work's Avatar
jon@work
I've always used NPT without using tape, and have never had any sealing issues. I think I spotted one of the original blanking plugs in the garage earlier, so I'll get the thread gauge on it tomorrow and let you know......
Old Jan 30, 2011 | 10:26 PM
wes's Avatar
wes
I'm not saying a 3/8" npt adapter / plug won't fit because they will, but the thread in the block isn't tapered
Years ago my old GGR engine was supplied with an alloy adapter in this opening, when i rebuilt that engine i wanted to put a new one in as it had seen better days, I didn't know what size it was so I took it along to think auto in Isleworth so they could measure it and they measured that fitting as a 3/8" bsp, I would hope that a supplier and manufacturer of threaded adapters would know their stuff
Old Jan 31, 2011 | 09:49 AM
jon@work's Avatar
jon@work
I've just measured an original blanking plug using a thread gauge. It has 18 threads per inch thread, so it is 3/8NPT.
Old Jan 31, 2011 | 09:53 AM
BRAMMER's Avatar
BRAMMER
Cheers Jon, wes
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
caprixpack
Sep 25, 2015 07:53 PM
