1.7 Puma Engine?
My Focus is a 1.6 Sigma.
Now I won't be doing this any time soon but it's nice to know different routes I could go down etc.
Now my Focus engines a little worn, it's done 70k of Start/Stop driving, burning a little oil but it pulls well. Next month it will be having a full servive
including timing and fan belt, waterpumps, tensioners etc. So the engine will be ok for a good while I think anyway.
Now I'm wondering how easy a 1.7 engine would drop in?
Now it's a common conversion with the Mk5 Fiesta ZS but I think there engines aren't as complicated as the Focuses. For instance the Focus has a air flow meter in the intake manifold and the fiesta has none.
I assume everything would bolt straight up including the 1.6 fly, box and clutch being the fact their the same engine
I'd be ok swaping the engines over, it's the wiring I would be stumped with.
Anyone know if this has been done on a Focus before? or how easy it would be?
Thanks, Bailes.
Thanks, Bailes.
Hi. Pumas and fiestas have airflow meters! The physical fitment of the engine should be easy enough, wiring wise may be different. The nice thing about doing this to a zs is that they have the same fuse box as a puma...meaning the puma harness and ecu plug straight in. Not too sure about the focus wiring tbh...
I'm someone can advise... A 2.0 might be a better choice though...focus to focus conversion will be easier!!
The 1.7 would be different and theoretically would be easier to drop in
Hi, used to own a Puma.
The 1.7 Puma engine has a VVT (variable Valve timing) system. Yes, It's common conversion with the Fiesta, as its basically a Fiesta Coupe.
1.7 Puma engine will be a lot more expensive to look after, for example when I had my Puma it cost £425 to get the cambelt changed (and it has to be done at 8yrs) not 10 years like the Focus belt.
I think you'll have a few problems TBH, you may as well save up the pennies and buy yourself either a MK1 2.0L Focus ESP or ST170 if you can live with the insurance costs.
Its a nice idea though!!
A 2.0 focus (not ST170) is not too bad to insure, only group 7 I think. I've found it to be the best compromise between insurance and performance anyway. As said, you'd be better off with a 2.0 car than messing about changing yours. If I were a gold member and you were nearer I could tell you about such a car that might be for sale.
I see its an old post but Bailes1992 would be nice to see how you got on as I'll be doing the same... Thats right 1.7 puma into my mk1 focus.
Why not a 2ltr or rs/st.... but I never take the easy route,
Firstly the puma came to me for free lol
also not bad spec's on it
1.7 puma is Variable Cam Timing Engine is 155 psi
LMS180 spec inlet
Inlet fitting kit
LMS stage two fully ported head
LM3 cams
Compression ratio raised to 10.9.1
Modified pocket Standard Pistons
LMS spec up-rated valve springs
Heavy Duty Rod Bolts
Panel filter
Power boost valve
Modified Induction System
Silicon Induction pipe
330cc Injectors
Vernier exhaust pulley
58mm knife edged throttle body
But would be grate to hear how the wring went or if anyone as done this before
LMS180 spec inlet
Inlet fitting kit
LM3 cams
Panel filter
Power boost valve
330cc Injectors
I have a 1.7 engine for sale currently
http://www.projectpuma.com/viewtopic...81372490f584d5
I am breaking a puma so any bits you need just let me know.
Alex
Alex
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
Ben26
Aug 27, 2015 08:56 PM
