Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
is this true? cvh gearboxes/fiesta 1.1 gearbox NEED ADVICE PLS
Old Jan 14, 2011 | 04:54 PM
rsturbolee's Avatar
rsturbolee
Default is this true? cvh gearboxes/fiesta 1.1 gearbox NEED ADVICE PLS
PLS SEE MY POST TODAY
my mates rs turbo gearbox is knackerd, for temp fix hes gonna fit one he has sat round till rebuilt his
he says any cvh geabox will fit it, the then pointed at a l reg 1.1 fiesta sat inside his workshop and sat thats the new temp gearbox!!! its an old pushrod engine lol
however when i popped the bonnet and examined the box it looked from what i could tell exactly like a cvh gearbox, bet it would pull like hell from the lights with the ratios from that, i said surely not that wont fit and he was willing to bet £20 it would so i presume hes confident lol
Old Jan 14, 2011 | 04:57 PM
Chaz888's Avatar
Chaz888
Not sure on that one think you might lose that 20 if you bet that is ??
Old Jan 14, 2011 | 05:06 PM
Ben26's Avatar
Ben26
ive got a 1986 gearbox in my FRST seems to be fine , but top gear runs out at 130 , i dont know if it cam eout of a 1.1 but very strange
Old Jan 14, 2011 | 05:26 PM
iansoutham's Avatar
iansoutham
OCD Victim
It will fit as it uses the same bolt pattern as the CVH, but will probably blow up on the 1st hard launch due to the ratios and the torque going through it
Old Jan 14, 2011 | 05:31 PM
rsturbolee's Avatar
rsturbolee
mad lol, ill have a blast in it and see what the difference is
Old Feb 3, 2011 | 04:24 PM
rsturbolee's Avatar
rsturbolee
gave my mate a hand to change the box today as the ramp was busy we had to do it on the deck also couldnt get the car that high so all against us
the box is bolted up fine, mounts changed for the life of us we cant get the cradle in right a real fucking ballache and head scratching moment, its like we need to move the engine or something its just sitting wrong, god knows whats up
near on 100 percent its not the box as i had them side by side to change the mounts over and reverse switch etc
wonder what the hell we could of done wrong, if slide the cradle over anti roll bar we cant for the life of us get the rear one right, with only one jack its a pain, got the rear of cradle bolted up and the front resting on the roll bar, cant seem to get it no were near the mount slot at mo, thinking maybe we need to get it on the ramp to see whats what atleast with a transmission jack will be easier to move the engine,
forgot how much of a pain it is to be led on the deck working like that i really nearly did take a hammer to the thing, if it was my car i prob would of done lol
Old Feb 3, 2011 | 04:31 PM
bookwyse's Avatar
bookwyse
The main diffrences will be to the cradle and if if has a bolt on or welded clutch arm. Apart from that the xternals are the same.
Old Feb 3, 2011 | 04:36 PM
rsturbolee's Avatar
rsturbolee
so the casings are deffo the same, well were using the rst cradle and rst mounts bolted to the box, would be nice to put the possibility of gearbox being slightly different to rest
the box has only got to last a couple months,the cars totally std at the mo so its only for hom to poodle to work and back in
Old Feb 3, 2011 | 07:47 PM
jamie's's Avatar
jamie's
defo fits
fitted many wrong gearbox's to rs turbo's/xr2's etc over the years
Old Feb 3, 2011 | 07:57 PM
ASHCOSSIE's Avatar
ASHCOSSIE
i ran a 4 speed 1.1 box on my old xr3
Old Feb 3, 2011 | 08:16 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Isn't that normal?
Lee, don't bolt one side up until you have a bolt in each side started, engine will move back and forward obv as its only on one mount if box isnt bolted up!
Old Feb 3, 2011 | 08:29 PM
bangerboy33's Avatar
bangerboy33
If u look at the mounting bolts for the engine mounts on the gear box u should notice they have built in spacers and I am sure the escort ones have a smaller spacer than the fester ones u need to change them I had to today for a escort into a fiesta hop this helps and is not to confusing
Old Feb 3, 2011 | 08:47 PM
rsturbolee's Avatar
rsturbolee
now that is something i didnt look at, on the gearboxes theres studs sticking out from the nuts and the mounts slide on and tighten with nuts over the top
are you saying the spacing on the gearbox nuts and studs sticking out is different? if thats the case you might well of hit the nail right on the head mate? all i can say is i had both boxes next to eachother but possibly just possibly i didnt notice
Old Feb 3, 2011 | 10:13 PM
bangerboy33
Yeah the studs the mounts slide over where they screw into the box they have built in spacers compare them just an idea but as I said had to screw the fiesta ones into the escort box so should imagine yours will b vice versa let me know if the studs r different cheers.
Old Feb 4, 2011 | 04:09 PM
rsturbolee's Avatar
rsturbolee
its bloody weird this one
we spent an hour on it today, it wasnt the bolt mounts, we dropped the roll bar to give the cradle more room, the cradle is now bolted up and the mounts for the studs have just about gone through the cradle holes so its sat in place, the trouble is its not quite right as its slightly rotated, the mounts can slide up and down in the cradle i presume so you can move the engine a tad.
can we move it can we feck, i had a lever bar inbetween the front gearbox mount and the front panel lifting to try to physicly rotate the engine a bit
tried pulling on the inlet manifold with all my force but feck all
basicly its prob 15mm out, only came to light when i went to b olt up the gear selector and its no were near the hole on the gearbox lol
tried jacking it up tried brute force etc
wondering if i should put engine on jack and let the engine top mount go and see if that helps, i have left the bottom mounts loose so cant see why they wouldnt slide in the cradle
any ideas?
Old Feb 4, 2011 | 07:27 PM
rsturbolee's Avatar
rsturbolee
up....
Old Feb 4, 2011 | 09:33 PM
vaughant's Avatar
vaughant
I had this problem on a fiesta mk5 which is the same basic shape as the mk3 frst.there's three bolts on the back of the box where it mounts to the cradle.their studs on the escort(poking out) and caphead bolts on the fiesta box.I tried doing all the thigs you said to no avail until I noticed this.
Pulled the box off,swapped the bits round and it flew back in,everything lined up spot on.
Old Feb 4, 2011 | 10:46 PM
rsturbolee's Avatar
rsturbolee
on mine were the mounts slide onto the box is some 17mm nuts and some studs, which when you undo takes the stud with it , the 3 for the mounts are exactly the same size on my fiesta box and the rst box
so basicly the gearbox mount bolts/studs are identical
Old Feb 5, 2011 | 02:51 PM
rsturbolee's Avatar
rsturbolee
up....
Old Feb 5, 2011 | 05:42 PM
cabriolet's Avatar
cabriolet
i had similar problem fella those rear mount studs is there a spare hole where they are i cant remember which car it was but we had to move one of the studs up one hole to rotate the gearbox round a little bit hope this helps
Old Feb 5, 2011 | 08:54 PM
rsturbolee's Avatar
rsturbolee
i will double check but im pretty sure ive got them in the right slot as the slot for them is a good inch or so long to allow for movement
its one of those things that wtf have i done here, luckily the cars in no rush to be fixed and its played with when theres free time but somethings wrong
Old Feb 5, 2011 | 09:02 PM
davexr3's Avatar
davexr3
i need a turbo.
deffo fits as do diesel boxes which are fine on a turbo
TPM961
Jan 15, 2018 10:50 AM
Bransby
Sep 11, 2015 09:12 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
gingeRS
Sep 4, 2015 06:29 PM
