engine rattle
Old Jan 12, 2011 | 08:45 PM
dmc2884's Avatar
dmc2884
Default engine rattle
hi i have a fiesta 2003 1.4 ghia only done 28k and has a rattle noise on the engine and stops when i put the clutch down, any ideas what could be causing this problem?
Thanks dan
Old Jan 12, 2011 | 08:47 PM
ginner's Avatar
ginner
trust bearing
Old Jan 12, 2011 | 08:53 PM
dmc2884's Avatar
dmc2884
is that an expensive job, it recently had the clutch done by mr clutch and had 2 years garantee so can take it back to them
Old Jan 12, 2011 | 08:55 PM
ginner's Avatar
ginner
i dont think they would of replced it mate but give them a ring it mite be covered ,
Old Jan 12, 2011 | 08:59 PM
dmc2884's Avatar
dmc2884
ok cheers mate nice one...
Old Jan 12, 2011 | 10:59 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Clutch release bearings in the ib5 boxes are notoriously noisy. My old box was, and my new box still is...
Old Jan 13, 2011 | 08:47 AM
Thrust bearing should really be replaced anytime you do a clutch, see if they did, in which case it's their problem.
Old Jan 13, 2011 | 09:47 AM
JonathanJ's Avatar
JonathanJ
Another issue with the IB5 box is gear "thrash" , used to get it even on fairly new cars , sometimes caused by incorrect oil in transmission or incorrect level , so would have a look at that as well seeing you have just had clutch replaced , would check what you paid for on invoice as sometimes they do not replace all items to keep prices down .
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
Roosie
Aug 13, 2015 07:40 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
