600+ BHP MK1 US spec Focus
Old Dec 17, 2010 | 12:25 AM
Jared's Avatar
Jared
560whp US spec Zetec
Default 600+ BHP MK1 US spec Focus
As of 2/15/10 build comprises of
2003 CD Silver zx3 purchased brand new 12-27-03 only options were AC (which is still intact and working!) cruise and alloy wheels. Completely stock exterior.
Supertech 8.7:1 pistons 85.5mm bore
eagle rods
ford bearings
zetec block bored to 85.5 mm decked .010"
Cometic head gasket .047" thick
ARP main and head studs
Custom ported head by me decked .025"
Supertech back cut valves
Eibach valve springs
Comp stage 2 cams
AEM cam gears straight up
Custom Top Speed intake manifold
all 3 VF engine mounts
Top Speed Pro-Race turbo kit GT3582r w/ TiAL SS .63ar turbine housing
3" hotside charge pipes 3.5" cold side
Custom Top Speed intercooler 3" in 3.5" out custom ducting to fit the front bumper
TiAL MVR wastegate dumped like a man!
TiAL Q 50mm BOV
3.5" SS Downpipe
4" Aluminum exhaust with 2 vibrant mufflers
return style fuel system with Dual walboro 255lbh pump in the stock tank
Top Speed fuel hat -8 feed line stock feed as the return
Top Speed -8 fuel rail
ID1000cc injectors
Aeromotive FPR 1:1 rise 50lb base fuel pressure
stock MTX-75 with 3.82 gear
Competition Clutch stage 5
Fidanza aluminum flywheel
Torsen atb diff
Eibach Pro System dampers
Intrax race springs
Eibach 22mm front sway bar 24mm rear
Lakewood traction bars
Hawk HP plus brake pads (I think)
17x8 et38 wheels
245-40-17 Hankook evo12 tires
AEM wide band
AEM Tru Boost boost controller/gauge
Top Seed Performance SCT custom tune
Bride Low Max ridged w/ custom aluminum brackets
Sparco 3" 6 point harnesses
Top speed custom .083" CM roll bar
Future plans
upgrade the brakes again adding some rear disc finally
I got this car as an early graduation present way back in December 2003 and it remained relatively stock until just recently. I have been building the car over the last 2 years and it has been a great ride. First I turbocharged the stock engine and continued to DD the car for about a year with a respectable and Mustang GT killing 265whp 265wtq.
10 and 12 psi
After finally picking up another DD (2001 Escape) I decided to push the stock motor and found its limit after a few weeks at 340whp 340wtq. But not before running a 12.7@ 114 on about 300whp and some old drag radials.
http://www.youtube.com/watch?v=vtWEv_E3Pwg
18-19psi slipping clutch
video, of coarse there is no time because as any of you who have ever been to KDS know, the timing lights don't ever work for very long!
http://www.youtube.com/watch?v=eDgjHLDmYrQ
300whp time slip
Here is what it reads:
Reaction: .092
I1: 2.096
I2: 5.584
I3: 8.345
MPH (I3): 88.235
I4: 10.641
E.T.: 12.712
MPH: 113.467
After the motor let go, I built up a junkyard motor with the usual forged pistons and rods and a custom ported head by me. The head alone landed me a respectable 30whp gain with stock cams. With the stock cams and intake manifold still in place I made 457whp and about 450wtq on 110octane and 30psi of boost.
http://www.youtube.com/watch?v=hd1DZvK1Fec
After realizing that, that was a shit load of torque, I decided I needed to get new cams and intake to transform some of that torque into big horsepower and I think I succeeded. After swapping the stock parts out for some Comp stage 2 cams and custom intake manifold I ended up with 50 more whp and 20 less ftlbs with 2 less psi of boost to make 504whp and 430wtq! I think that is pretty respectable for a zetec powered Ford Focus with a GT3076r.
Time slip but only on 21-22psi or about 420whp and 93octane.
Video from the next day, faster 60' but slower 1/8th because the track sucked and I was spinning 2nd
http://www.youtube.com/watch?v=MDI6uViQkok
Now if I can just get the weather to cooperate so I can get back to the track for a new time!
Recently, I sold my previous Turbo kit and decided it was time to build the most bad ass, no compromise turbo kit ever to be installed on a street driven focus. The result, I think, was incredible. See the top for pics. Even more impressive was the power it unlocked. A best of 561whp and 434wtq. It still made more than impressive numbers at low boost as well. Here are a few dyno charts at 9, 16Psi respectively.
Idle video
http://www.youtube.com/watch?v=rrHduqKgtaw
Below is a comparison of my old setup with the same GT3582r but different Kit and intake manifold. The red line is the new kit at 25psi, and the blue line is the old one at 27psi with 3" DP and no exhaust. As you can tell the new kit is making significantly more power on less boost, also note the gain in spool. I think some of this can be attributed to the new intake manifold, but also the removal of the old restrictive 3" Down pipe.
Dyno Video
http://www.youtube.com/watch?v=qjZc7TnhE6g
Old Dec 17, 2010 | 01:00 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
That is awesome! So 'ordinary' on the outside. Would love to own that!
Old Dec 17, 2010 | 01:18 AM
botters's Avatar
botters
competant bodger
epic mate must be one of if not the most powerfull zetec out there?
Old Dec 17, 2010 | 05:26 AM
scortpower's Avatar
scortpower
love it, that engine would look great in my silver st170. how much that set you back?
Old Dec 17, 2010 | 09:03 AM
Sp3no's Avatar
Sp3no
WOW, thats immense, what an engine!!!
I am in the middle of turbo chargin my Focus ST170 (SVT) the aim is 400BHP on pump fuel and i was planning on using the GT35R turbo but after seeing your figures im thinking the GT35R turbo may be a bit overkill for 400bhp
Old Dec 17, 2010 | 09:05 AM
AustenW's Avatar
AustenW
Nice work
Old Dec 17, 2010 | 09:13 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Nice
Old Dec 17, 2010 | 12:06 PM
Jared's Avatar
Jared
Defiantly overkill for 400bhp, I would go with the gt3076r it will give better spool characteristics and that will still give you some room to grow. It would easily be good for 500bhp.
Old Dec 17, 2010 | 12:13 PM
Jared's Avatar
Jared
I stopped keeping record of it a long time ago, I don't like to think about it. I did port the head and build the engine myself so that saved me a lot. And the fact that the engine is nothing special and not very radical at all. A very good friend of mine owns a shop here in the states and he was nice enough to lend a hand on the things i could not do myself, like all the pretty welds he laid down. Most of the parts are available for purchase though him. the link is in my sig.
Old Dec 17, 2010 | 12:39 PM
scortpower's Avatar
scortpower
this makea me think about getting the spare st170 engine setup i got turbo'd.
SP3NO- have you got a thread going on with your build would be interested to see. i have a spare st engine running in my written off st170. if it dont sell i were gonna look into a turbo setup for it
Old Dec 17, 2010 | 07:50 PM
AustenW's Avatar
AustenW
What 1/4 mile times have you run?
Old Dec 17, 2010 | 08:12 PM
focusrrx87's Avatar
focusrrx87
look at his sig, lol
11.4 @ 123mph
Old Dec 17, 2010 | 08:17 PM
AustenW's Avatar
AustenW
Sorry missed that
Seems low on terminal for such a high bhp?
Old Dec 17, 2010 | 10:25 PM
Jared's Avatar
Jared
Sorry missed that
That was last year on 93 octane and a different kit. It was about 450bhp give or take.
Last time I went to the track I was around 540bhp. I was having trouble hooking up, I only ran 11.6 but it was at 132mph.
Old Dec 18, 2010 | 05:42 AM
AustenW's Avatar
AustenW
Thumbs up
I'm not knocking you by the way, you have achieved some excellent results there
If you can get it to hook up I'd expect a late 9 @ 150 with those power figures comparing it to some of the guys here in europe
Old Dec 18, 2010 | 05:48 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Nice sleeper
Old Dec 18, 2010 | 12:37 PM
Jared's Avatar
Jared
My car is not lite enough for 150mph trap. The guy doing 150mph is in a fiesta that is 2100lbs with him in it. Mine is 2750 w/ me in full street trim with most of the interior A/C power steering. My car would need about 700bhp to trap 150.
Old Dec 18, 2010 | 05:05 PM
Sp3no's Avatar
Sp3no
Just been looking at your inlet manifold, is the first part bolted to the head a standard SVT plastic part? ever had trouble with the manifold parting at this point under boost? What managment are you using? And it looks like a standard MAF sensor your running?
Sorry for the questions.
Got plenty of pictures of my build, its taken 6 months to get to this point and i think its going to take another 12 to finish, will do a build diary when i get a chance.
Old Dec 19, 2010 | 08:57 PM
mac82's Avatar
mac82
that is awesome!!
Old Dec 19, 2010 | 09:21 PM
tezmanian devil's Avatar
tezmanian devil
that's sooooooooooo cool! where do i find one of those exhaust manifold's you have? lookied through the site in your sig but cant seem to find it
Old Dec 20, 2010 | 01:34 AM
Jared's Avatar
Jared
its this one HERE
Old Dec 20, 2010 | 01:44 AM
Jared's Avatar
Jared
Yes this is correct, It saved a ton of cash not to have a metal machined flange made. Also it helps dramatically in the reduction of heat soak. No problems with it and running up to 25psi on it so far.
Engine management is the stock computer remapped using SCT software. They are very big in the states, especially with the mustang which is the biggest motorsport market here. Fortunately the focus has gotten some love due to the technology being directly applicable and "trickling down." It uses the all the stock sensors including the MAF and provides complete control over all its functions. The re-map was done by me.
Old Dec 20, 2010 | 01:57 AM
Fiddy's Avatar
Fiddy
Love it, from the outside the car looks stock, bet it surprises a few people out on the road.
Old Dec 20, 2010 | 08:27 AM
Sp3no's Avatar
Sp3no
The states does seem to cater for the focus market much better than here, that software by SCS is immense, i was planning on fitting full aftermarket managments but i think im going to give the SCS software a go. More import duty to pay
If your using all the standard sensors how does the standard managment sence boost? You still have the VVT working.
Old Dec 20, 2010 | 08:43 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Very cool car.
Awesome
Old Dec 20, 2010 | 11:57 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
It looks like a normal, non-vvt, 2-litre to me?
Old Dec 20, 2010 | 01:14 PM
Sp3no's Avatar
Sp3no
your right, i had it in my head it was the svt focus originally, this is the stumbling block on the ST170 turbo conversion, it has a black oak ecu so the software this guy used to re-map his ecu may not work
Old Dec 21, 2010 | 01:55 AM
Jared's Avatar
Jared
I have the standard black top motor.
It doesn't actually read boost, it just measures the amount of air going into the motor. You just use the stock MAF sensor and increase the diameter of the pipe. When doing this you have to re-scale the range of the sensor. It is a little challenging at first especially if you are used to working with a MAP based system, But once you get it all figured out it is actually very simple. Timing is based off load so the more boost you run the more power you make therefore the more load so that is how you can adjust the timing for boost. The biggest problem with it is not a problem at all but the fact that there is so much that can be changed it is hard to know where to start.
Old Dec 21, 2010 | 07:58 AM
Sp3no's Avatar
Sp3no
Once again i appolagise for the questions, are SCS able to supply you with a start up base map that you can work from?
Old Dec 21, 2010 | 10:45 AM
Jared's Avatar
Jared
Yes but in order to do more than 200whp you have to change the size of the pipe the MAF is in which is where it starts to get tricky.
Old Jan 1, 2011 | 05:10 PM
dug112y's Avatar
dug112y
passionford pro
so take the vvt off and use a std blacktop ecu with the scs software...maybe need to get a new inlet cam or lock the st one.
Old Jan 1, 2011 | 05:26 PM
andy130's Avatar
andy130
looks mad, bets it fun on the road? are these the piston your using?http://cgi.ebay.com/ebaymotors/Super...Q5fAccessories
Old Jan 3, 2011 | 10:36 PM
Sp3no's Avatar
Sp3no
I actually have a spare Blacktop engine in the garage with a recently rebuilt head. Will the inlet cam from the blacktop drop straight into my ST170 head? i really really wanted to keep the VVT though
Old Jul 6, 2011 | 01:16 PM
AustenW's Avatar
AustenW
Any updates with this?
Old Jul 6, 2011 | 08:57 PM
scubastevo's Avatar
scubastevo
Lovely fella would love to take that to a track, the full package in sheeps clothing glad your not on our roads there be a few red faces lol
Old Jul 6, 2011 | 09:21 PM
J1mbo's Avatar
J1mbo
B1mbo
Did this make 500+WHP on a gt3076 and 28 psi?
Old Nov 12, 2011 | 06:24 AM
Jared's Avatar
Jared
Yes, that turbo gave great spool too.
Old Nov 12, 2011 | 06:26 AM
Jared's Avatar
Jared
Last time I took this to the track I threw the clutch through the belhousing. I am in the middle of an epic RWD conversion. But Its slow going with a newborn girl around the house at the moment.
Old Nov 12, 2011 | 05:50 PM
J1mbo's Avatar
J1mbo
B1mbo
What flywheel power is it with 28psi and gt3076?
Old Nov 13, 2011 | 01:11 AM
Jared's Avatar
Jared
Most likely around 540-550bhp which is right in where garrett rates the turbo.
