ECU and TPS question
Old Jan 29, 2005 | 09:15 PM
cossy abuser's Avatar
cossy abuser
Default ECU and TPS question
Got a 4x4 and putting it back to L6 from L8 and PF01 from PF09 due to the fact the car has a 2wd engine loom fitted
Was running with 2wd loom and L8 and PF09
Will I have to reverse the outside two wires on the TPS plug when going back to L6?
If they are the wrong way round, what will it do? Rev the nuts off with a closed butterfly or just not run atall?
cheers
Old Jan 30, 2005 | 07:49 AM
alan rainbow's Avatar
alan rainbow
the wires will need swoping around if you dont it will run irattic
Old Jan 30, 2005 | 04:18 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i don't see what you're hoping to acheive
a 2wd loom will work properly with the pf09 and L8 if the outer 2 wires of the tps connector are correctly positioned (at both the tps and ecu ends)
Old Jan 30, 2005 | 05:28 PM
cossy abuser
if you change the wires at the ECU end and the TPS end you will not end up changing anything
The "WD loom cannot accomodate the Knock sensor so why use a L8 when the motor is nothing special, and I have a stage 4 chip for a L6
Old Feb 1, 2005 | 10:39 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i said if the wires are positioned correctly at both ends, i didn't say anything about swapping them at both ends.
why use a L8? because they're better (more memory and map sites) and can support both the knock sensor and a lambda sensor if you have the right one and add a few wires to the 2WD loom.
fair point on the chip, but i'd rather run stg 4 on L8 than L6.
DixieTheKid
11
Jun 6, 2020 11:20 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
liamT74
Sep 23, 2015 10:24 PM
DixieTheKid
Sep 14, 2015 09:04 PM
