mondeo tddi heating issues
Old Nov 27, 2010 | 12:48 PM
leslover's Avatar
leslover
Default mondeo tddi heating issues
hi, i have a problem with my heating, firstly the gauge in the car doesnt register when driving, only when sat still, and then it take ages to move, and secondly when driving the heaters are only ever warm, not hot, even after 30 mins driving, the expansion tank doesnt seem to hold much pressure either, it gets hot, but i can still unscrew cap and no steam etc...it doesnt use any oil or water, but i think mpg is down tho.....any ideas please?
Old Nov 27, 2010 | 01:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
thermostat?
Old Nov 27, 2010 | 02:47 PM
leslover's Avatar
leslover
could/does this sound like the oilcooler 1? or the other....obviously oil cooler 1 is cheaper!
Old Nov 27, 2010 | 03:04 PM
RichieST's Avatar
RichieST
If the temperature goes up when in traffic, then drops off again when moving, 100% thermostat.
Old Nov 27, 2010 | 07:25 PM
leslover's Avatar
leslover
there is 2 isnt there??? dya know which 1 it is most likely to be and the location please?
Old Nov 27, 2010 | 07:32 PM
RichieST's Avatar
RichieST
No idea i'm afraid, change the easiest one first then see what happens. I've got an inkling that its the later tdcis that have 2 stats, might be wrong though!
Old Nov 28, 2010 | 06:37 AM
leslover's Avatar
leslover
cheers il av a look....its a tddi though
Old Nov 28, 2010 | 09:18 AM
martysmartie's Avatar
martysmartie
As said sounds like thermostat (Stuck Open) to find the convential thermostat simply follow the top radiator hose back to the housing which is on the head. Don't know about the secondary thermostat on the Tddi, I should think it's something independant from the cooling and does something to the fuelling on the diesels?
Martin
Old Nov 28, 2010 | 02:35 PM
leslover's Avatar
leslover
sounds like that's right to me,thanks. the mpg is slightly down, il av a look once weathers a bit better, thanks
Old Dec 11, 2010 | 05:07 PM
leslover's Avatar
leslover
sorted new thermostat and housing fitted (as it was done!) 10 min job, lovely n warm now!!!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Brickhouse
Sep 20, 2015 11:47 AM
roomey
Sep 19, 2015 08:40 AM
cossie09
Sep 10, 2015 06:56 PM
