mk3 mondeo rear wash dislodged
i had no water form the back jet, upon looking i find under the headlinnig right at the top of the tailgate, the pipes has come loose....question is, i have a pipe from the right where the water comes out, and 1 from the left with a white end in? how do i connect them to the jet? i have a bung on the car that i can push the water pipe thro, but i cant get it to fit into the back of the jet on roof...and does the other need to join it somehow? is there a t peice or something that connect these, then into roof???
looked in haynes and cant make it out??!?!!!
cheers lee
cheers lee
sorted...... upon investigation, i found the pipe that comes from right is in fact an aerial wire!! and the reason no water was coming from the other was...... the pipe had been cut under the were it connects to the washer jet, hence no water !!
03-11-2015 04:08 PM
