RST Head Gasket
Old Nov 20, 2010 | 05:58 PM
JamesyRS's Avatar
JamesyRS
Default RST Head Gasket
Simple question, fitted new genuine ford head gasket to realise I hadnt put washers on bolts so had to take them out, will head gasket be ok with new bolts torqued down or will it need a new one again? Ordering bolts just now so thought Id better ask. Also bolts say 18/41 lbs/ft then 90 degrees then 90 degrees again am I better doing it this way or how the haynes maual says?
Old Nov 20, 2010 | 06:04 PM
s1cab's Avatar
s1cab
if you have tightened the head then i would get a new headgasket for def !peace of mind
Old Nov 20, 2010 | 06:10 PM
JamesyRS's Avatar
JamesyRS
cheers mate, I thought that myself just thought Id get a second opinion. cheers
Old Nov 20, 2010 | 06:15 PM
s1cab's Avatar
s1cab
no probs
Old Nov 20, 2010 | 07:37 PM
The HG will be perfectly ok to use again, as not been heated ?
I've got the new plug, so will try and sort in the morning for you.
Old Nov 20, 2010 | 07:48 PM
chaffe's Avatar
chaffe
Turbocharging Technician
as tabetha said, gasket will be fine! some manufacturers actually say to torque the head, then slacken it and torque it all over again, helps bed the gasket into the sufaces
Old Nov 20, 2010 | 10:13 PM
JamesyRS's Avatar
JamesyRS
was never heated fitted and started putting everything back together then relised washers in bolt tub was like shit!! Saves me some dosh if its ok and awesome mate got to wait on new bolts coming anyway so no hurry
Old Nov 21, 2010 | 04:51 PM
I have your sump plug tapped to 1/8 NPT-27 sat here on me desk, will post in morning for you.
The reason why the hole isn't dead centre is because the "nut" part of the plug isn't in line perfectly with thread part, bloody shocking quality really, they are obviously just spat out of a machine, it will do the job perfectly though, they are a very hard metal(lot of carbon) not quite 10 form hard but plenty strong enough.
Old Nov 22, 2010 | 01:20 AM
JamesyRS's Avatar
JamesyRS
awesome mate, your some guy!! Much appreciated as usual tabetha, not worried about centre, as you said you did what you had to do a will be happy to get the sensor in there when I do oil change big thanks to you
Old Nov 22, 2010 | 12:35 PM
No probs matey, happy to help, saves having to buy a tap for just 1 hole!!
Old Nov 22, 2010 | 01:59 PM
JamesyRS's Avatar
JamesyRS
legend
Old Nov 22, 2010 | 02:15 PM
Didn't have time to post yesterday, so was posted about 15 minutes ago, anything else you need help with(FOC) just ask.
Old Nov 23, 2010 | 12:31 AM
JamesyRS's Avatar
JamesyRS
thanks buddy, new headbolts should be here tomorrow so hopefully have it ready for mot during week, a will happily give you a shout been great help to me since joining cheers
Old Nov 23, 2010 | 12:44 AM
botters's Avatar
botters
competant bodger
headgasket will be fine mate, my pal changed into second instead of 4th at santa pod in his fiesta turbo instantly destroying most of his valves, he managed to find a head for sale at a trader stand so duly got the spanners out and swopped the head over using the 30,000 mile plus headgasket lol! it got him back home to preston
i asked him about 2 months later if he had swopped it for a new one and he still hadnt lol! i wouldnt reccomend reusing to this extreme tho haha
Old Nov 23, 2010 | 01:05 AM
JamesyRS's Avatar
JamesyRS
thats impressive just thought id get peace of mind as better to stick a new one in if needed, but hadnt even run it yet so will be fine, good help the guys on here, new to this building engine stuff but giving it a go as garage and tuners expenses threw the roof!!
Old Nov 23, 2010 | 04:29 AM
JesseT's Avatar
JesseT
I would definately not change the gasket, but I would make sure to unslacken the bolts and fit the washers one by one. New bolts would be on my list though.
Old Nov 23, 2010 | 11:57 AM
JamesyRS's Avatar
JamesyRS
yeah new bolts came today I just took them all out as didnt know what damage etc leaving one out would do didnt want to knacker head all good just about to go out and do again with WASHERS this time!! Got sump plug tabetha, its perfect mate thanks again!
Old Nov 23, 2010 | 06:13 PM
Jesus that arrived quick, I didn't want to tap it any deeper as trying to preserve some edge of the nut.
Old Nov 23, 2010 | 07:24 PM
chaffe's Avatar
chaffe
i hope you checked the length of engagement with a go/nogo npt plug gauge lol
Old Nov 23, 2010 | 10:27 PM
JamesyRS's Avatar
JamesyRS
well fits perfect mate very happy can finally get last gauge working now got a question for you, fitted new head bolts today, I have my own torque wrench but only goes to 80 nm and final stage is 100-110 according to haynes manual, so used mates but turned a few times more than I thought was needed so stopped, will this have warped head? was only 1st bolt? got myself worried now if this is warped it being broken for parts. Found out that my mates torque wrench is fooked, so ordered new bolts yet again and a nice new torque wrench!!
Old Nov 24, 2010 | 09:39 AM
I would just torque the other ones up with a decent reading torque wrench, being slightly overtight on stretch bolts isn't going to kill it, will be fine, so long as it's not like 5 turns extra!!
Old Nov 24, 2010 | 09:41 AM
NO, never do, I just screw in a sensor to set the depth, the problem with the sump plug is there is so little metal left on the outside hex part, and the fact that the thread part was not in line with the hex, good old ford quality, so centre of thread found on lathe was not centre of hex, so had to leave a little bit shallow, but works fine.
Old Nov 24, 2010 | 10:02 AM
chaffe's Avatar
chaffe
i was joking, its only a bloody drilled and taped hole min
Old Nov 24, 2010 | 10:29 AM
JamesyRS's Avatar
JamesyRS
he took it back out I dont know how many turns he gave it, this car been a nightmare since the start of this, think Ill just take it off and have a check over it for peace of mind dont want to put it all on to find out it fooked, cheers again mate think ill do it myself this time with my new 'working' torque wrench
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
