what do i have to change to fit a cossie t3 to my s2?
Old Nov 3, 2010 | 05:57 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default what do i have to change to fit a cossie t3 to my s2?
as above,im sure ive heard something needs to be swapped? can anyone help??
Old Nov 3, 2010 | 06:34 PM
rsmark86's Avatar
rsmark86
the down pipe i have and i also have a stage3 t34 .48 its a top spec with all the fittings including a new feed pipe ect...
Old Nov 3, 2010 | 07:12 PM
rickbartlett
G911 TTA
does down pipe need changin then? cant i just swap the bit that the downpipe bolts up to?
how much u askin for the stage 3 aswell mate out of interest
Old Nov 3, 2010 | 07:31 PM
rsmark86's Avatar
rsmark86
na mate you need a cosworth rear exhaust housing to get any benifit other wise you might aswel keep the rst t3...
im after Ł500 for the whole set up its a nms spec turbo
custom made down pipe that slots in to you rst 2.5" exhaust
turbo complete done 2k and built to run at 2bar lol
actuator and bracket
new oil feed and mint return pipe
and has the water pipes for a s2 aswel
whole lot
Old Nov 3, 2010 | 07:39 PM
rickbartlett
G911 TTA
id be very tempted if i could shift the van ive got for sale on this forum,hardly had any interest which is surprising as they proper rare now.
my t3 is shagged,only reason im asking this is cos a mate has offered me his t3 cheap off his cossie,basically i wudnt be bothered about a big benefit,as long as it would be as good as a normal t3 id be happy.
if my van sells asap id snap that up!
Old Nov 3, 2010 | 11:24 PM
rsmark86's Avatar
rsmark86
let me know mate its in the rs turbo parts section im breaking a full running gear
Old Nov 3, 2010 | 11:33 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if you're not bothered about getting more out of it significantly, then remove the exhaust housing from the shagged turbo and fit the cossie core into the exhaust housing.
it could be as easy as that, assuming the 6 bolts come out of the housing without all snapping.
Old Nov 4, 2010 | 12:44 PM
rickbartlett
G911 TTA
nah im not bothered about big gains its just that ive been offered one and i just need the car working again.
Old Nov 4, 2010 | 06:16 PM
rickbartlett
G911 TTA
nobody else ever done this then?
Old Nov 4, 2010 | 06:56 PM
12_Second_rst's Avatar
12_Second_rst
you can get a 5 bolt .48 housing that will fit the cossie t3 and can bolt to the standard rs turbo elbow and still be a stage 3 t3
Old Nov 4, 2010 | 08:41 PM
little bram's Avatar
little bram
Its a easy job to do mate just need to make a down pipe and cut and move the actuator down. you can make a down pipe using a standard cosworth down pipe. Can jano not help you with exhaust and actuator brackit. he puts cosworth turbos on his cars
lee
Old Nov 4, 2010 | 09:12 PM
rickbartlett
G911 TTA
ive pm'd jano to ask as some people are tellin me all i have to do is rotate the turbo snail,some are tellin me i have to change the exhaust housing and some are saying i need an actual cosworth down pipe!
and i just need a definite answer before going ahead with it
Old Nov 4, 2010 | 09:58 PM
little bram
ha well ive got a pic but its not the best.
i made a down pipe using a cosworth down pipe then i just bolted the my escort exhaust on.
Old Nov 5, 2010 | 06:49 AM
rickbartlett
G911 TTA
by looks of that pic,i could bolt my exhaust housing elbow off my old turbo to the cossie t3 and then conect my exhaust up to it???
Old Nov 5, 2010 | 09:35 AM
rsmark86's Avatar
rsmark86
get it mate and i will sell the down pipe from mine ... which is a perfect fit into your exhaust
Old Nov 5, 2010 | 12:26 PM
rickbartlett
G911 TTA
but by the look of that pic,if i fit my elbow to that turbo ,then my exhaust will bolt strait up to it???
Old Nov 5, 2010 | 01:38 PM
wilky's Avatar
wilky
just bolt your .36 exhaust housing from your rs to the cossy turbo job done
and you'll have a bigger comp wheel so be a bit of an up grade
plus you can sell me your cossy housing
Old Nov 5, 2010 | 03:47 PM
rickbartlett
G911 TTA
ive spoken to jano,i just have to fit my exhaust housing and bolt my exhaust up to that
Old Nov 5, 2010 | 05:59 PM
little bram
theres no point mate you mite aswell leave your turbo on and i don'nt think you can do that anyway. don'nt think you can put a .36 exhaust housing onto a cosworth turbo thats ment to have a .48 housing on.
Old Nov 5, 2010 | 06:25 PM
johnenright150rst's Avatar
johnenright150rst
Had a knackard t3 on my erst, bought a cossie t3 off my brother cheap
Then all I did was take the cossie core out and put it into my original housing
Works fine.
Probley would have had more benifits to use the cossie housing but I just wanted to get it back on the road.
Hth cheers John
Old Nov 5, 2010 | 07:42 PM
little bram
looks like am wrong. must fit but still would'nt bother.
Old Nov 5, 2010 | 08:57 PM
rickbartlett
G911 TTA
my t3 is fucked completely, so to get me out of the shit im gonna fit it with my housing and then when i can afford a cossie downpipe i will refit the cossie housing
Old Nov 6, 2010 | 10:35 AM
Karlos G's Avatar
Karlos G
Balls Deep!
That will be basically a Stage 2 T3 so will be good for 230bhp and quite responsive too, well worth the change
Old Nov 6, 2010 | 01:12 PM
rsmark86's Avatar
rsmark86
pm sent mate
Old Nov 6, 2010 | 02:00 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
As karlos said its the same sort of thing that companys would call a stage2. It would be better with a .48 CVH style fitting, off a saab or volvo so it would have a better exhuast housing. You can use the cossie housing which works better than the CVH style, as i explained to Rick if you do this you will need a custom downpipe and also an actuator bracket.
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
lockie
Jul 31, 2015 10:03 PM
