Cleaned the underside of my cosworth (NOW STARTED WELDING 20/04/12)
Well its been a year now since i have even really looked under the car with winter looming and not alot going on i have been think about painting up the underside of my motor.
My motor has only done 87,000 and it was garage all its life before i brought it so i was hoping it would be to bad...
When i first got it i 3m shuttes the back end just to be on the safe side (now i wish i hadn't cause its fidderly to clean off).
i will let the pics do the talkin.
Started with the pressure washer
This is how it came out, i know its not prefect but its a hell of alot easier to work on now...
(thats not rust on the shell its the underseal that is stuck on there)
There is some bits have a bit of surface rust that need minor attention but on the whole i was pleased with myself for the rest of the day.
Nice job on the cleaning btw, you sure got a minter there!
Has anyone had there colour mixed up in gloss paint before??
couple of my mates are painters and decoraters and they reckon i can get a colour mix very close to mine!!
Has anyone used it? does it last....It says on the tin Metal??
strip it, clean it, fresh spray sealer and then 2k paint
that easy mate
brush all ur parts up and refit , or powdercoat if u got the pennies
that easy mate
Right so its been awhile since i touched the old girl ive been busy with other stuff like jetsking and off roading, O and getting a new workshop.....
so after all that fun its back to the cosworth for the short time i got her in the workshop a couple of weeks ago to see what needed doing, i new in my heart of hearts it would need a alittle bit of welding like they all do so between me and a couple of mate we brought a 185 mig welder and got started. i will let the pics do most of the talking!!!!
Thats the driverside here is the passanger side, not bad for only really been welding for the last 6 months!!!
so i have a few more bits that i have found and while the carpet and everything is out i mite as well do it.
I have tried my hardest to make sure you cant see then plates that i have fitted, me and my mates are pretty happy with how they have turned out.
i will be doing more later or over the weekend so look out for the updates.....
rog
Sep 4, 2015 12:10 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
