on the dyno at Dastek today
Old Oct 7, 2010 | 06:33 PM
kermitt's Avatar
kermitt
Default on the dyno at Dastek today
Took my RS to Dastek in Fife today for a setup and to fix some niggles. Have to say very professional and credit to Russel who knows his stuff.
Unfortunately the dyno highlighted that my actuator was possibly weak as it was only making 0.3 bar of boost (about 5 psi) hence only getting 160bhp at flywheel. Probably due to me fitting it but have my old one to try out.
Looks like I can remove the starter to swap it over, is that correct?
Anyways hopefully that will fix the problem some more boost and should be able to achieve 200 bhp.
Old Oct 7, 2010 | 10:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Dont need to remove anything to change the actuator mate.
Old Oct 7, 2010 | 10:44 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Whats your spec mate?
Old Oct 8, 2010 | 07:50 AM
kermitt's Avatar
kermitt
Standard rebuild bottom end and head,
Airtec FMIC,
Magnex exhaust,
K&N induction kit
Chipped ECU,
Stage 1 T3
Running MFI
Still to fit Koni adjustables and a OMP front strut brace. Hopefully getting a cage soon and maybe some new racing seats.
Old Oct 8, 2010 | 08:23 AM
Dom-hkl's Avatar
Dom-hkl
Does anyone know if a focus rs ecu will fit a turbod up zetec 2.0 and Willkie go straight on the loom etc and sorry couldn't find anywhere more appropriate or how to start a new one thanks .Dom
Old Oct 8, 2010 | 01:17 PM
KSA-Cossie's Avatar
KSA-Cossie
Had my saph on their rollers and was impressed with them.
Old Oct 8, 2010 | 02:02 PM
essexRSTSouthend
Might be worth a look.car sounds like it running good dude!i had same problem with weak actuator,7psi was my max lol.still made 160 odd with pretty standard spec like yours.
Old Oct 8, 2010 | 02:48 PM
kermitt's Avatar
kermitt
Yeah Russ said it was very good numbers considering there was sod all boost. So how do I remove the actuator then without removing starter motor etc?
Old Oct 8, 2010 | 03:05 PM
chaffe's Avatar
chaffe
Turbocharging Technician
Good power for f*'k all boost mate. try tightening the actuator you have, slacken the 11mm lock nut and screw in (shorten the rod) by about 5mm, this will give you more boost and tighten the actuator up. If you pull of the boost controll pipe to the actuator does it still only make 5 psi?
Old Oct 9, 2010 | 12:03 AM
Karlos G's Avatar
Karlos G
Balls Deep!
The two 10mm nuts holding it to it's bracket, and the C clip on the waste gate arm.
Old Oct 9, 2010 | 02:12 AM
rsmark86's Avatar
rsmark86
as karlos mate said its an easy job then adjust it like chaffe said till you get the boost you want
Old Oct 9, 2010 | 07:24 AM
stwibs's Avatar
stwibs
once you have set the boost you will need to take it back to get fuelling checked.
Old Oct 9, 2010 | 04:23 PM
kermitt's Avatar
kermitt
Job done seems to pull stronger now. Disconnected the crappy boost gauge I had as it sounded like a leak coming through the dash.
Gonna pop out later for a quick run and check over hopefully track day tomorrow!
Old Oct 9, 2010 | 04:49 PM
Chopshop85's Avatar
Chopshop85
160bhp from 5psi?!? surely not.
Old Oct 9, 2010 | 05:19 PM
chaffe's Avatar
chaffe
how much boost does it hold now then mate?
Old Oct 9, 2010 | 05:34 PM
kermitt's Avatar
kermitt
At the flywheel yes, 100 or so @ the wheels.
Dunno what boost I don't think the cheapo gauge was working. Feels a bit more lively now and not as flat. Only turned it two turns on the actuator.
Old Oct 9, 2010 | 09:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah the dyno is way off there, a brand new RST 20 years ago only made 132bhp at 7psi
Old Oct 9, 2010 | 09:54 PM
chaffe's Avatar
chaffe
i agree, must be nearly 110 bhp at that boost?
Old Oct 9, 2010 | 10:01 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Airtec FMIC,
Magnex exhaust,
K&N induction kit
Chipped ECU,
Stage 1 T3
Running MFI
Yeah none of those mods will give it any more power at 5psi.
Shows how far out Dyno's can be! lol
Old Oct 9, 2010 | 11:16 PM
Chopshop85's Avatar
Chopshop85
Well I have pretty much the same engine aside from the stg1 turbo, And mine makes 165bhp @15-16psi
Old Oct 10, 2010 | 09:07 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Stage 1 is just 360 thrust bearing so no actual flow gains, his IC will help but not until running over 12-14psi, so just a standard RST really.
Your figure is pretty much what I would expect for that spec and boost.
Old Oct 10, 2010 | 05:47 PM
ryan_gwa's Avatar
ryan_gwa
How much was it at Dastek? Going to need a decent fuel set-up and run on the rollers when mine is done. Miles away yet, but nice to know.
Ryan
Old Oct 10, 2010 | 06:12 PM
Rob_DOHC's Avatar
Rob_DOHC
Think i removed my rad and interwarmer which made it really easy.
Rob,
tankybaby66
Feb 6, 2016 02:24 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
Vacuman
17
Sep 18, 2015 04:42 PM
JamboRS
28
Sep 14, 2015 09:02 PM
