can i drive with no tax/mot on trade plates
im buying a ford transit from a company that they no longer use but it has no tax or mot i need to drive it 1/2 mile home they say i can use there trade plates will this cover me.
Yes,but the vehicle must be roadworthy and you can't have any passengers in it with you.I'm not 100% sure whether you need to work for the company to be covered via their trade plates?might be best to get one of their staff to drive it seeings as it's such a short distance?
Description
A trade plate and associated Trade Plate Certificate (valid for 12 months) can be obtained for a range of motor trade related purposes. A trade plate authorises the use of a vehicle that would normally be required to be registered.
The plate is denoted with a 'M' prefix followed by four numbers and has black characters with a yellow background.
A trade plate may be used for the following:
Conditions of use
Conditions of use for a trade plate are:
- to demonstrate or test drive a vehicle
- to proceed to an exhibition or show to display or trial the vehicle and return
- to move a vehicle to or from a place where repair or maintenance work, including painting is undertaken.
Conditions of use
- by a person authorised by the holder of the plate
- for no longer than 36 hours at any one time
- to be attached correctly to the rear of a vehicle (or other location as permitted) and be clearly visible.
- of each occasion a trade plate is used on a vehicle
- at the place of business of the holder of the trade plate
- be made available for inspection.
so to the op as i believe it
you can pick up vehicle as required
for reasons below
1) your taking vehicle for repair ready for mot
2) you have permission from plate holder to use plate (as long as he keeps a record of you using it and its not more than 36hrs )
for reasons below
Trade plates cover a car that has no ROAD TAX only , there are people who think you can drive a car with no MOT on and you CANT , unless you are on the most direct route to an MOT station , and if thats the case you dont need trade plates to do that anyway , just insurance
RB26DETT
Feb 5, 2022 01:54 PM
Si B
Sep 12, 2015 06:49 AM
