Anybody a PuTTY guru?
Old Sep 18, 2010 | 07:04 PM
Stu.H's Avatar
Stu.H
Default Anybody a PuTTY guru?
Just a bit of break from the norm ...
Basically, I need to copy a folder from a directory that is on a Linux o/s share to another folder on an FTP that is on my LAN, but from my laptop (which is on wireless)
I need GB speeds across the 2 OTHER devices due to the filesizes (they are on the same GBLAN).
Is PuTTY the best way?
And do I use PuTTY logging on using FTP (port21) or SSH (port22)?
I probably didnt explain myself great, but you might get the jist...
Any help appreciated!
Old Sep 18, 2010 | 07:06 PM
Jim Galbally's Avatar
Jim Galbally
putty is only a console thing, telnet or SSH will make no difference.
tlnet to device, run ftp command.
connect to ftp on other device, start copy.
google "how to FTP" or similar
Old Sep 18, 2010 | 07:12 PM
Stu.H's Avatar
Stu.H
See using an FTP client on my laptop and copying from the one device to the other has to go through my laptop IE the WLAN... I want to instigate the copy from the Linux box and have the laptop ignored.
I'll try telnetting, see how I get on, although I thought PuTTY was similar .....
Ta
Old Sep 20, 2010 | 11:18 AM
tsutton's Avatar
tsutton
Log on to the server and then within that console, type in ftp (assuming it's installed on server) and the ftp client will load up from there.
Then you can ftp between 2 servers without having to use your bandwidth on laptop/wifi. And it will be faster as it's server to server transfers.
Old Sep 20, 2010 | 12:09 PM
Jim Galbally
what he said. the question you meant to ask is "does anyone know how to FTP from a linux console" as oposed to "how do i use putty" all putty will do is give you the remote console.
FTP is a protocol, not a program
Old Sep 20, 2010 | 12:32 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Agreed, once you have a command prompt in your telnet window its just a case of opening an ftp connection and doing a GET xxxxx
mgtkr1
107
Dec 6, 2016 04:23 PM
FiestaFREAK92
Mar 16, 2010 10:22 PM
nickywarwick
Insurance
Jul 7, 2009 09:16 PM
Apr 8, 2009 04:20 PM
