Damn thing won't start!! **Now works as of 04/10/10**
Old Aug 28, 2010 | 07:34 PM
Sonic Boom's Avatar
Sonic Boom
Default Damn thing won't start!! **Now works as of 04/10/10**
Right lets see if the collective genuis of PF can get my 3 Door started.
In May I blew the engine up at Brunters got it AA towed home drove it off the back of the recovery truck on 3 cylinders into the garage.
Had the engine rebuilt and new Ryan loom made up (the only things that are new to the car)
Put the whole lot back together now it won't start.
No Spark and sometimes the injectors don't fire either (noid tested)
When you turn the key the coil fires all plugs once then nothing.
These are the parts I have changed:
Coil Amps (Both)
Coil (tried 2 different ones)
WRC Cam Sensor (3 different ones)
2 Phase Sensors (tired putting the old dizzy back in and then another one to make sure)
HT Leads
Crank Sensor
Map Sensor (just cuz I had a spare one)
Loom
ECU
Also put my old loom back on to check Ryans but it still wont start i've cleaned up all the earthing points and even added extra earths direct to the battery.
And to really make it wierd it did start for about 30 seconds when we think the dizzy was timed up incorrectly haven't been about to reproduce that thou
Rich
Old Aug 28, 2010 | 07:37 PM
XRSTI's Avatar
XRSTI
Coolant temp sensor on back of head?????
Old Aug 28, 2010 | 07:44 PM
rs_turbo_tony's Avatar
rs_turbo_tony
Originally Posted by Sonic Boom
Right lets see if the collected genuis of PF can get my 3 Door started.
Coil Amps (Both)
HT Leads
Crank Sensor
Loom
ECU
Rich
you got it running yet mate ,
Old Aug 28, 2010 | 07:53 PM
BRAMMER's Avatar
BRAMMER
Is fuel getting in there? are the plugs shot??
When mine had a firing issue i checked every sensor, timing, fuel in, 3 set's of plugs, coil pack and it turned out to be the diaphragm in the FPR was shagged and fuel was flooding the engine - new rail, clean out and a set of fresh plugs and it started.
Some points people were advising me were - are any of the wires from the loom touching the body where it goes through the bulkhead.
Old Aug 28, 2010 | 08:05 PM
Sonic Boom's Avatar
Sonic Boom
All brand new sensors, engine will run even if the CTS in disconnected.
Rich
Old Aug 28, 2010 | 08:06 PM
Sonic Boom's Avatar
Sonic Boom
Clearly not!
Rich
Old Aug 28, 2010 | 08:08 PM
Sonic Boom's Avatar
Sonic Boom
The FPR is a brand new Aeromotive one fitted about 200 miles before I blew it up.
I rewrapped the the whole car loom before the engine went back in so i'm pretty sure nothing is rubbing plus the engine loom is brand new.
It's seriouly doing my head in now.
Rich
Old Aug 28, 2010 | 08:29 PM
AndyPen's Avatar
AndyPen
My mates brand new aeromotive FPR was faulty when he had it rolling roaded recently... thought it worth mentioning.
Old Aug 28, 2010 | 08:51 PM
LHD220Turbo's Avatar
LHD220Turbo
had the ecu tested?
Old Aug 28, 2010 | 10:07 PM
Sonic Boom's Avatar
Sonic Boom
Still wouldn't cause the no spark issue.
Rich
Old Aug 28, 2010 | 10:08 PM
Sonic Boom's Avatar
Sonic Boom
Originally Posted by LHD220Turbo
had the ecu tested?
Tried my ECU in Ian's 3 Door aka COLLEYST200 and it ran his car fine.
Rich
Old Aug 28, 2010 | 10:22 PM
BRAM's Avatar
BRAM
sounds like it has a immobilizer on have you had that checked?
Old Aug 28, 2010 | 10:52 PM
Sonic Boom's Avatar
Sonic Boom
Yup it's got a Clifford on it but it turns off ok.
Rich
Old Aug 29, 2010 | 01:02 PM
The Crocodile Hunter's Avatar
When i had mine apart i managed to put the phase sensor connector on the wrong way round and it wouldnt start
Only stopped the injectors working tho??
The only time i've lost spark on mine it was the ignition amp
Old Aug 29, 2010 | 01:40 PM
Sonic Boom's Avatar
Sonic Boom
Ye no fuel or sparking in the wrong order would point to a dodgy phase sensor but i've change it twice on the wrc cam trigger sensor and twice on the dizzy phase sensor.
Rich
Old Aug 29, 2010 | 02:45 PM
luckymitchell's Avatar
luckymitchell
i had the exact same thing in my 3dr, tried everything you have...turned out to be the ecu, which was strange as it was not even touched when i rebuilt the engine.. the ecu would run other cars, but not the one it came out of, told a few people this and nobody had an explanation.bought a L6 and it fired up first flick of the key..worth a try with someone elses ecu...
james
Old Aug 29, 2010 | 04:07 PM
Turbosimpsons's Avatar
Turbosimpsons
try changing your leads round on your coil pack.
Old Aug 29, 2010 | 04:13 PM
Sonic Boom's Avatar
Sonic Boom
james
I'll see if I can find another L8 with coilpack conversion.
Rich
Old Aug 29, 2010 | 04:14 PM
Sonic Boom's Avatar
Sonic Boom
Yep tried that too, still nothing.
Rich
Old Aug 29, 2010 | 05:33 PM
rs_turbo_tony
Clearly not!
Rich
do you need a hand i can pop around have a look if you want
Old Aug 29, 2010 | 09:40 PM
Turbosimpsons
have you swapped 1 and 3 with 2 and 4. some seem to spark opposite to others.
Old Aug 29, 2010 | 09:47 PM
Sonic Boom's Avatar
Sonic Boom
Ye and tried another coil with the numbers printed on it too.
Rich
Old Aug 29, 2010 | 09:48 PM
Sonic Boom's Avatar
Sonic Boom
Hopefully taking it down Reyand early next week now.
Rich
Old Aug 29, 2010 | 10:00 PM
RONNIE AMIS's Avatar
RONNIE AMIS
was just about to say mate, just take it to a specialist, not dissing any body on here but you'll ask a question get 20 different answers and confuse yourself, give it to a speciailist and job done then
hope you get it sorted mate
Old Aug 29, 2010 | 10:15 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Have you inverted the wires on the WRC cam trigger?
I seem to recall they need swapping round...
Old Aug 30, 2010 | 06:40 PM
Sonic Boom's Avatar
Sonic Boom
Probably the best thing to do it's driving me nuts now.
Rich
Old Aug 30, 2010 | 06:42 PM
Sonic Boom's Avatar
Sonic Boom
On the new loom Ryan surplies he inverts the wires on the loom, but also surplies a fly lead for if your still running a dizzy with the wires the normal way round I did try it with the fly lead too just incase but still nothing.
Rich
Old Aug 30, 2010 | 07:21 PM
BRAM's Avatar
BRAM
Are you using a 2wd loom and a l8 ecu, when my brother done this on his escort he had to swap the wires round on the crank sensor to get it to start, worth a try
Old Aug 30, 2010 | 08:24 PM
Sonic Boom's Avatar
Sonic Boom
The loom was custom made, but I put my old loom back on which worked before I blew it up and still nothing
Rich
Old Sep 5, 2010 | 11:20 AM
rs_turbo_tony
sounds like you need one person to look at it and stick to it mate .wot crank sensor are you using ? is it sitting closer anough to pickup and i have had problem with swopping wires around before now worth a try .i think your gona end up kicking your sef mate .if its some think really silly
Old Sep 5, 2010 | 05:24 PM
Sonic Boom's Avatar
Sonic Boom
It's down at Reyland as we speak so hopefully Martin will hand be back a fully functioning 3 Door
Rich
Old Sep 6, 2010 | 02:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I hope Martin sorts it out for you
Steve
Old Sep 14, 2010 | 06:27 PM
rs_jim's Avatar
rs_jim
have you got it back from reyland yet ?
Old Sep 15, 2010 | 06:42 AM
cossie891's Avatar
cossie891
Mine was like that it was the relays under the dash
Old Oct 4, 2010 | 06:25 PM
Sonic Boom's Avatar
Sonic Boom
And what was causing all the problems?
It was the Crank Pulley (after market alloy one)
Don't ask me why it worked on my old engine and not on this one all I care is that it's working now.
Thanks to Martin @ Reyland (for all your diagnostic needs)
Rich
Old Oct 4, 2010 | 06:47 PM
bad boy rs's Avatar
bad boy rs
what a strange fault, did reyland say why it was at fault ?
Old Oct 4, 2010 | 08:03 PM
pauloopnorth's Avatar
pauloopnorth
crank sensor faulty/worn ?
Old Oct 4, 2010 | 10:09 PM
Sonic Boom's Avatar
Sonic Boom
Might be that the leading edges on the 4 picks aren't that great, put a standard crank pulley on and it ran fine.
Rich
Old Oct 6, 2010 | 07:33 PM
BRAMMER's Avatar
BRAMMER
Crazy but at least it's working
JoeyBoyden
Jan 4, 2024 02:36 PM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
