fitting motec ecu help needed :-)
Old Aug 3, 2010 | 05:52 PM
derekd's Avatar
derekd
Default fitting motec ecu help needed :-)
hi fitting in a motec in my cossie and am i right in thinking the REF cable is for the crank sensor and the SYNC is for the phase sensor ???
just want to confirm this as its the last 2 cables to wire up cheers
Old Aug 3, 2010 | 06:04 PM
oldford's Avatar
oldford
From the help file: REF Sensor Supplies the crank position information.
You can reach the help from the PC-program that you can download for free from Motec.
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Porplus12
Sep 10, 2015 07:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
