fitting motec ecu help needed :-)
hi fitting in a motec in my cossie and am i right in thinking :-)the REF cable is for the crank sensor and the SYNC is for the phase sensor ???
just want to confirm this as its the last 2 cables to wire up cheers |
From the help file: REF Sensor Supplies the crank position information.
You can reach the help from the PC-program that you can download for free from Motec. |
© 2024 MH Sub I, LLC dba Internet Brands
