Electronic boost controller help??
Old Aug 2, 2010 | 10:48 AM
RS Classics's Avatar
RS Classics
Default Electronic boost controller help??
Hi I was wondering what side of the amail valve I need to have the boost controller located on. For it to function properly.The side that goes from amail to actuator or turbo to amail? It's just a high boost switch you control from inside.
Old Aug 2, 2010 | 12:27 PM
martysmartie's Avatar
martysmartie
If you mean the "2 stage boost" mod as some call it (in fact all it is is merely on/off), then you simply cut the earth for the amal which goes back to the ECU and put a switch between.
When the switch is open you will have low boost, but when the switch is closed full boost will be restored.
Martin
Old Aug 2, 2010 | 09:20 PM
RS Classics
No I have a controller that is attached to a solenoid that goes between the turbo Nd actuator. You can adjust it inside with a knob and flick it to that high with a aircraft switch. What I need to know is. Where do i put the solenoid in the line. Before or after the amail valve. Or do I need to take it out for the controller to function properly?
Old Aug 2, 2010 | 09:30 PM
rsnissan's Avatar
rsnissan
Do away with the AMAL valve and use your boost controllers solonoid
Old Aug 2, 2010 | 09:52 PM
RS Classics
But isn't it a safety feature to stop it overboosting? Will the map sensor do the same job incase it overboosts?
Old Aug 2, 2010 | 09:57 PM
rsnissan's Avatar
rsnissan
Its not a safety feature to stop it overboosting, its basically a standard version of the solonoid you are fitting that is controlled by the ECU. Its the chip that has the overboost protection so thats dependent on what one you are running. The MAP sensor will let the ECU know what boost the car is running so if the chip has overboost protection it doesnt matter what is controlling the boost.
Old Aug 2, 2010 | 10:05 PM
RS Classics
Thanks mate.
Old Aug 2, 2010 | 10:18 PM
rsnissan's Avatar
rsnissan
no problem, what make is the boost controller out of interest?
Old Aug 2, 2010 | 11:13 PM
RS Classics
HDI
Old Aug 3, 2010 | 10:01 AM
RS Classics
Another thing I was wondering. ( I'm only 16 and learning haha). I want to get a stage 1 closed loop chip from motorsport development. It's going to run 15 for that chip. With my boost controller. Would I save fuel if I ran only like 8 -10 psi as low boost and flick it to high when I want more power. Or would it use the same amount of fuel at low boost as at high as it's ment to run that amount. Or will the ecu reload this and use less fuel?? Thanks heaps
Old Aug 3, 2010 | 10:03 AM
RS Classics
It's an l8 green top
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
