Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Removing MK6 Escort Steering Wheel
Old Jul 25, 2010 | 07:41 PM
Definitive van's Avatar
Definitive van
Default Removing MK6 Escort Steering Wheel
As title can anyone advise me on removing the wheel before i have a go
Thankyou
Old Jul 25, 2010 | 07:45 PM
Mark_'s Avatar
Mark_
need to disconnect the battery for an hour or so so the airbag doesnt go off,
there are 2 screws in the rear of the steering wheel which will allow you to remove the cover then the airbag. you will then be able to remove the steering wheel
Old Jul 25, 2010 | 08:56 PM
Definitive van
Is leaving the battery off for an hour a must or will disconecting it be enough ?
Old Jul 26, 2010 | 08:47 AM
Definitive van
any extra advice before i tackle the job
Old Jul 26, 2010 | 05:27 PM
Mark_'s Avatar
Mark_
Originally Posted by Definitive van
needs to be left of for about an hour as the airbag could still go off if you just disconnect then mess about with the bag straight away
Old Jul 26, 2010 | 06:05 PM
F500 CON's Avatar
F500 CON
disconnect battery remove two screws out of back of steering wheel remove front panel and remove nut that attachs steering wheel!i dont know about leaving battery disconnected for a hour could be right but i never have probably worth checking that though as u dont want it going off
Old Jul 30, 2010 | 07:12 AM
kristinthomas21's Avatar
kristinthomas21
Refitting is the same as removal, but you can make sure that the air bag is suitable for the new bike because it is spoken of three four versions spoke. Also take precautions to straighten extreme wrapped connector. This is what gives the bag to remain connected to the wheel turned left and right. To get this thread could be dangerous Short airbag off while driving.
Old Nov 11, 2011 | 11:38 AM
iancott's Avatar
iancott
Hi Guys, need sum help. my girl friend as a ford fiesta mk6 zetec, and trying to get the steering wheel off, there are two spring clips at the back where you have to put in a screw driver tried everything and is a nightmare, there must be a knack to this, i have disconnected the battery. any help. Ian
JoeyBoyden
Jan 4, 2024 02:36 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
fatboy billy
Aug 3, 2015 08:34 AM
