fuel pump wiring
Old Jul 18, 2010 | 06:04 AM
B13 JUS's Avatar
B13 JUS
Default fuel pump wiring
i have rewired my fuel pump and used the old live as the trigger.
i thought the ecu triggered that live to tell the pump to work?
as soon as i turn my ignition on i have constant power to the pump whichout turning the engine over.
i thought the pump was supposed to stop untill the engine is turning over??
Old Jul 18, 2010 | 09:27 AM
The original set up is the ecu trips the relay close to the ecu connector then relay powers out to pump itself through cut out switch.
Old Jul 18, 2010 | 09:51 AM
RS500/364's Avatar
RS500/364
Best way i found was to use the trigger in the old relay connector
Old Jul 19, 2010 | 08:39 AM
B13 JUS's Avatar
B13 JUS
what i need to know is..
should the ecu send the signal to the pump as soon as the ignition is switched on and stay on?
or should it stop untill the engine is turning over?
Old Jul 19, 2010 | 09:17 AM
The ecu should send an initial 2-3 second burst for priming first thing in the day, and then dependant on other factors may do so again, seems to be it's mostly engine temp related as to whether it does so or not, after the 2-3 secs without engine running it should stop, and remain stopped until engine cranking and/or running conditions are met.
Old Jul 19, 2010 | 09:24 AM
B13 JUS's Avatar
B13 JUS
ok cheers mate, i will check mine again as i thought it was running and not stoping when i turned the ignition on but not sure is the car was warm when i checked it.
Old Jul 19, 2010 | 09:29 AM
Paul_RS's Avatar
Paul_RS
My car primes for roughly 5-10 seconds when cold IIRC. Just let it run and see if it cuts out
JK12
33
Apr 26, 2021 12:09 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
