Ported and polished 1.8 blacktop zetec head
Old Jul 14, 2010 | 06:30 PM
hineho87's Avatar
hineho87
Default Ported and polished 1.8 blacktop zetec head
Is this worth doin to improve gains with mods iv got? any worthwhile gains and rough costs of gettin this done.
Iv got full exhaust/induction mods, plus iv got kent cams/pullies. Car is a 1.8 focus blacktop.
Thanks
Matt
Old Jul 14, 2010 | 06:35 PM
woolford's Avatar
woolford
not massive gains as the valves are smaller than 2.0l
Old Jul 14, 2010 | 06:55 PM
hineho87's Avatar
hineho87
thats fair enuff. I was jus reading forums and stuff to pass time at work and it said about porting inlet and exhaust valves to improve performance
Matt
Old Feb 21, 2011 | 01:20 PM
Tyres's Avatar
Tyres
If you're talking about the blacktop zetec 1.8 2.0 valves are exactly the same size 28/32.Only the chaber geometry is different . So If you put a 1.8 head to a 2.0 bottom it'll result in a 11:1 comrpession ratio.
Old Feb 26, 2011 | 03:19 PM
martyn focus's Avatar
martyn focus
would it make much difference as i have just got a 2.0 focus and what would the gains and plus side of this and down sides of this be
Old Feb 26, 2011 | 06:30 PM
Sp3no's Avatar
Sp3no
Them comp ratios are too high for standards pistons and rods.
Old Mar 8, 2011 | 01:20 PM
Tyres's Avatar
Tyres
Not true Not true at all.... the zetec engine 1.8/2.0 internals are quite strong.No problem coping with the increased compression when you change your 2.0 head with 1.8. SO if you're running a 2.0 zetec in focus with full exhaust ,head ported (1.8 to benefit from the high compression) and the cams and pulleys it WILL be a nice and quite powerful daily driver. N/A ALL THE WAY mate!!!!!!!!! No regrets at all! I don't know what are the gains from the increased compression ONLY but I'm sure it'll be around 10hp.
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 12, 2015 06:42 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
