oil change now white smoke???
Old Jul 12, 2010 | 09:06 PM
drl's Avatar
drl
Default oil change now white smoke???
Hi all did an oil change on the weekend (used 15/50 mobil 1 fully sythetic) and every time i start my s2 from cold i get white/grey smoke. when the car is warm deres no smoke on idle, im pretty sure im gettin puffs of smoke on overrun so im guessin the oil seals in the turbo hav gone? can i put a thicker oil in to stop it seepin past the seals in the turbo?
Old Jul 12, 2010 | 09:20 PM
studabear's Avatar
studabear
no, I wouldn't go any thicker
Check you haven't over filled the oil
Also could be valve stem oil seals (easy fix)
Old Jul 12, 2010 | 09:33 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
exact same thing happened to my mate on his old cossie after he changed the oil mate never did find out what was wrong with it tho!
Old Jul 12, 2010 | 09:43 PM
drl's Avatar
drl
the oil level is above max but wud dat cause it to smoke?
also wud i not get puffs of blue smoke and no smoke on overrun if it was stem seals?
Old Jul 12, 2010 | 10:45 PM
kermitt's Avatar
kermitt
Over filling is bad news for oil seals and creates excessive pressure in the engine. Firstly drain some oil out, you could just remove the oil filter to do this depending upon how overfull it actually is. Don't think it would be a good idea to run the engine until you do.
Take the charge carrier pipe off and the boost pipe to the turbo and see if there is oil in each. If so it could be your turbo oil seals.
Smoke on overrun suggests worn valve guides, stem seals or turbo oil seals. Do the above first then post your findings.
Stem seals is easiest if you have the tool for the job (less than Ł10 for one) but if you drop a valve collet down a hole in the engine the sump will have to come off to recover it. Best to block all holes with rags first.
Valve guides is a head off job and give it to a pro to do. You will need to budget probably Ł100 to have it done plus new head gasket and head bolts (about Ł60).
Failing that the turbo needs to come off to be replaced so you will need to remove the bumper, rad and intercooler to get the best access. Obviously this will be more expensive route (approx Ł500 for new turbo) so make sure your fault diagnosis is correct first.
You may be lucky once you remove the excess oil the problem will stop but you may have damaged something already.
Old Jul 25, 2010 | 12:03 AM
drl's Avatar
drl
hi all, been really busy lately lol
ive removed the boost pipe, top pipe from charge carrier and the bottom pipe and dere was loads of oil in them. the sharft in the turbo has got quite alot of up and down play in it, so does this all point to a new turbo?
if so, wat turbo wud be best?
im runnin 10 psi wid a few mods i.e. exhaust, piper cam ..... ive got standard intercooler
Old Jul 25, 2010 | 02:37 PM
white2lsr's Avatar
white2lsr
Would you run your car with oil below the minimum mark? probably not so why run it over the maximum mark as its just as bad for your wngine?
Old Jul 25, 2010 | 05:44 PM
kermitt's Avatar
kermitt
I would check all the engine oil seals just to be sure.
Sounds like the turbo has had it. No point getting an uprated replacement without getting a better intercooler first. Autospecialist's one is good if on a budget cos a turbo will probably cost you Ł500 anyway.
Its normally not a good idea to get a second hand one of ebay cos it could have problems too.
Old Jul 27, 2010 | 05:08 PM
drl's Avatar
drl
hi the oil level was literally just past the max mark so dnt think dats d cause of the prob...
can i just buy one of those turbo rebuild kits off ebayz and rebuil it myself? does the turbo need to be balanced after puttin it all back together?
thanks
Old Jul 27, 2010 | 05:11 PM
white2lsr's Avatar
white2lsr
No you cant rebuilt it yourself. It wil cost anywhere from Ł200 upwards to have yours rebuilt.
Old Jul 27, 2010 | 05:21 PM
rubinsbin's Avatar
rubinsbin
2 much oil in dat der motor dat cud be d cors wiv it, eye wud tek sum out m8t, than nos!!!!
Old Jul 28, 2010 | 07:34 AM
kermitt's Avatar
kermitt
If the turbo shaft is not balanced to the very fine tolerances required you could fook the turbo all over again. Best get a pro to do the job.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
YODI
Aug 30, 2015 01:12 PM
