MTX75/ST170 6 Speeder?
Old Jul 12, 2010 | 04:12 PM
mattseries2's Avatar
mattseries2
Default MTX75/ST170 6 Speeder?
Decided im going to fit one of the following to my zetec turbo.
Anyone fited them? Need some info on them etc...Pics would be good!
In terms of shafts i know Jano and Sitech make customs one for both boxes, but has anyone made any? If so have you and pics sizes lengths etc??
Matt
Old Jul 12, 2010 | 04:15 PM
Luca's Avatar
Luca
Lukesville
Fit Focus RS box!
Old Jul 12, 2010 | 04:23 PM
mattseries2
Luke!
Find me one then!!!
Old Jul 12, 2010 | 04:38 PM
crazycage's Avatar
crazycage
i have fitted the mtx to both escort and fiesta turbos and got a 6 speed to fit to a cvh .and made my own shafts too.
Old Jul 12, 2010 | 07:45 PM
Luca's Avatar
Luca
Lukesville
Originally Posted by mattseries2
Luke!
Find me one then!!!
what next... fit it too!
Its far easier to fit that box and cheaper too, im sure a few posts on wanted section and call to breakers you will find one.
ST170 ones are about but you dont get the fancy diff with those
Old Jul 13, 2010 | 10:06 AM
Bomber's Avatar
Bomber
Possible to fit a 6 speeder to a Silvertop Block/sump? I don't fancy swapping out my sump with all the bits done on it.
Old Jul 13, 2010 | 11:12 AM
crazycage's Avatar
crazycage
yes thats easy
Old Jul 13, 2010 | 11:31 AM
Bomber's Avatar
Bomber
yes thats easy
So how would it be done? I know you'd need to grind a bit of the block on the Silvertop as the starter fouls on the edge, and on the Blacktop the sump has pickup points for the gearbox itself. Then I am assuming that you'd need to make a custom bracket up to enable the use of the equal length driveshafts on the silvertop block?
Failing that I'd love to be able to fit the 6 speeder into my Mk1 - but using the same bolt holes/front starter as a BC box as then I can mount it on a bearer and not have to faff with custom mounts.
Possible to weld a BC bellhousing to a 6 speeder?
Old Jul 13, 2010 | 01:50 PM
crazycage's Avatar
crazycage
the box will bolt up fine with the 6 bolts onto the block, and yes you will need a custom braket for the centre shaft,luca had one made when he went dry sump have a look in his resto
Old Jul 13, 2010 | 02:06 PM
Luca's Avatar
Luca
Lukesville
just bolt on the st170 sump and use the half shaft and bracket as standard
Old Jul 13, 2010 | 02:14 PM
crazycage's Avatar
crazycage
or a standard 2.0l blacktop sump.tho he said he didnt want to.defo the best way to go imo
Old Jul 13, 2010 | 02:20 PM
mattseries2
You dont get your hands dirty Luke!
If one comes up for the right money ill have it!
Old Jul 13, 2010 | 03:03 PM
mattseries2
Does the Focus RS box fit the same as the MTX?
Old Jul 13, 2010 | 03:44 PM
Bomber's Avatar
Bomber
Crazycage: So how did you fit the 6sp to a CVH?
Old Jul 13, 2010 | 04:37 PM
crazycage's Avatar
crazycage
i cut a small part of the bell housing off the bc box and welded it into the getrag casing for the starter motor.
Old Jul 13, 2010 | 04:43 PM
mattseries2
Anyone fitted an Focus RS box? Is it the same as a MTX75 box?
Old Jul 13, 2010 | 04:48 PM
crazycage's Avatar
crazycage
how manny time's do i have to tell you this ? the focus rs is a mtx!! it is the same as any focus mtx .but not the same as the old stity mtx from a rs2k and only one bolt hole on the top mount different from the mondeo mtx.
Old Jul 13, 2010 | 05:10 PM
mattseries2
You havent told me otherwise i wouldnt ask!
But thanks for the info!
Old Jul 13, 2010 | 05:34 PM
crazycage's Avatar
crazycage
really ?
have look here lol
https://passionford.com/forum/ford-e...o-gearbox.html
Old Jul 13, 2010 | 05:44 PM
mattseries2
I do apologise! Forgot about that thread! Thanks for all the info though, im just trying to get my head round what to go for and what i need to get for it lol!
Old Jul 13, 2010 | 05:55 PM
crazycage's Avatar
crazycage
box from a focus (you can pick up the rs when you find one)
gear stick and cables from a focus (but must be from one that has a mtx fitted)
clutch and flywheel (any 2.0l zetec flywheel and a focus rs clutch)
custom top mount for box (i can sort this if you want)
focus rear gearbox mount
and a set of shafts
then you just need to sort the hydraulic clutch ( i do a kit that bolts in)
Old Jul 13, 2010 | 06:03 PM
mattseries2
and a set of shafts
Thanks mate thats very helpful!
I may need the mount and hydraulic clutch kit off you. Pm me prices
Old Jul 13, 2010 | 07:11 PM
project rs's Avatar
project rs
well for 1500 you can drop the car off and in 2 weeks pick it back up again all done and fitted including the focus rs clutch (with normal mtx box unless customer has the frs box then the cost of our box is taken away) only thing that would need doing is the new mounts colour coding as we leave then seem sealed and primed for customer to have that sorted at a later time
Old Jul 13, 2010 | 07:28 PM
Bomber's Avatar
Bomber
Do you think it would be possible to weld the entire bolt pattern edge and starter bulge of a BC to a Getrag?
Sorry to the OP for going off topic.
Old Jul 13, 2010 | 07:41 PM
crazycage's Avatar
crazycage
theres no need the bolt patern is the same ,but im not sure if you could or couldnt do it.
you could get a addaptor plate made from ally easy tho.
Old Jul 13, 2010 | 08:16 PM
project rs's Avatar
project rs
was this hard to do as thinking of putting a 6 speeder on my cvh
Old Jul 13, 2010 | 09:07 PM
Bomber's Avatar
Bomber
Didn't think it was 100% the same along the bottom - I need the exact same configuration to enable me to use my Mk1 XR2 gearbox bearer.
I'll look further into it.
Old Jul 13, 2010 | 09:17 PM
crazycage's Avatar
crazycage
your right its not the same along the bottom.
rallycross
22
Mar 9, 2014 12:56 PM
purplebargeken
Ford Range
Jun 22, 2013 09:14 PM
Fil
148
Jul 19, 2012 06:46 PM
BLACKCOS
21
Nov 20, 2008 07:01 PM
