GOTECH
Old Jul 10, 2010 | 12:20 AM
RSMK4TURBO's Avatar
RSMK4TURBO
Default GOTECH
Hi is anyone using Gotech engine management on theyre RS?Ive been told by my mechanic that i should be looking into efi mappable engine management and i have heard that Jamsport have had good results from this system.
The spec of my car is.
k&N induction kit
Mongoose exhaust
piper 285T2 cam,pully
full frontal airtec intercooler
Collins chip
Turbo technics stage 3 t3
Currently running 17-18psi of boost,would i benefit from Gotech now or should i get my zvh conversion done first which i plan on getting done in future.Any advice would behelpful cheers.
Old Jul 10, 2010 | 08:28 AM
Karlos G's Avatar
Karlos G
Balls Deep!
EFI gains include, power, response, economy, and reliablilty so yes go EFI first!
IMO ZVH is a waste of time, either run a good CVH or go Zetec turbo, ZVH has all the bad points of a CVH engine, none of the good points of a Zetec, and requires big money spending on headwork, manifolds, and a big turbo to get a nice power band!
Almost any standalone management will be fine including Gotech, speak to whoever you will have map it and see what they recommend for best results
Old Jul 10, 2010 | 09:46 AM
Bryan_RST's Avatar
Bryan_RST
i have gotech on mine and it is fine had no problems with it and had it fitted and mapped at jamsport
Old Jul 10, 2010 | 09:53 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i have alot of problems with it so i moved away from it. not saying its bad at all just the people who supply it
Old Jul 10, 2010 | 06:52 PM
project rs's Avatar
project rs
it hs it's good points but if you put it up against a megasquirt as they are about the same all fitted and mapped the megasquirt blows it out the water i consider slow-tech a more track management where you are mostly at wot and there it copes well
Old Jul 10, 2010 | 10:50 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Thanks for advice gents,will have to look to see what else is available before i commit.
Old Jul 11, 2010 | 02:54 PM
morph's Avatar
morph
What makes megasquirt better than gotech? i thought a management was much more about the tuner mapping ability rather than just a standalone management system?
Old Jul 11, 2010 | 04:32 PM
project rs's Avatar
project rs
no if it was just that then dta and a few others would be a bit cheaper it's also about it's speed at which it works and the way in which it does it like megasquirt can interpalate(spelling) between load sights, where as you have to input every parameter into gotech and the amount of features each has or can preform to aid in the smooth operation if you get a chance to use the software for both you'll see what i mean
Old Jul 11, 2010 | 04:48 PM
1223456's Avatar
1223456
Dont forget the additional features which you get with ms:#
idle control
nos control
boost control
launch control
antilag
etc etc
these are all standard on ms but im pretty sure only the top end gotech will accomodate these.
If you are going to use the gotech ecu which obtains the cp from the dizzy then im pretty sure this wont have idle control. I bought this for my car but then sold it before fitting as quite a few people had informed me problems with starting and the engine hunting once warm, would imagine this to be pretty anoying on a road car but for a track car it probably would'nt matter.
Old Jul 11, 2010 | 05:09 PM
JonnyBravo's Avatar
JonnyBravo
I'm going to be using V4 soon, as far as budget ecu's go it would appear to be in a league of its own, it won't be long until more people have switched over to it and I'm sure it will then be more accepted by people.
Only seen one car on Gotech which was done by someone we all know and it was removed in favour of Pectel T2 iirc
Old Jul 12, 2010 | 10:06 AM
SiZT's Avatar
SiZT
I imagine that Go-tech can interpolate or the majority of cars running it would still be getting mapped now. It's probably just the Go-techs resolution when interpolating between sites is worse than Megasquirt's.
MarK4
Sep 24, 2008 03:39 PM
S2_RST_DK
Jun 9, 2008 08:15 AM
Joe1199
May 20, 2008 05:54 PM
c.fogarty
May 19, 2008 04:48 PM
Joe1199
Apr 25, 2008 08:15 PM
