series 1 wont fire!, after alternator fitted! help
Old Jun 29, 2010 | 02:51 PM
mintseries1's Avatar
mintseries1
Default series 1 wont fire!, after alternator fitted! help
hey all,
fitted alternator yesterday and the car started first time, took it for a spin all was well and put it to bed, got in from work today went to take the car for a blast and it wont fire!!!
will this be down the a faulty alternator????
Old Jun 29, 2010 | 03:50 PM
conor.rst's Avatar
conor.rst
What happens when you turn the ignition ? dose it just click ? or dose it acctually turn over.
Old Jun 29, 2010 | 03:53 PM
mintseries1
it turns over mate just wont fire up!
Old Jun 29, 2010 | 04:00 PM
conor.rst's Avatar
conor.rst
Wouldent of said it was the alt then ..... have you checked the plugs ?
Old Jun 29, 2010 | 04:16 PM
mintseries1
na mate that was my nxt step!!
Old Jun 29, 2010 | 04:50 PM
conor.rst's Avatar
conor.rst
Yeah check spark and the plugs mate, might be time for a new set
Old Jun 29, 2010 | 05:20 PM
mintseries1
cheers for the replys mate,
they have only been on there bout 3 months! surely they should last longer than that!!!???
Old Jun 29, 2010 | 10:04 PM
RSargie's Avatar
RSargie
check your fuses and relays, what amp/voltage alternator have you fitted? could it be to high and have blown a fuse? also check fuel pump is working and fuse for heated seats if its like a s2.
Old Jun 30, 2010 | 07:05 PM
mintseries1
Right went out to see if it wud start, and yes it started first time!! Came home, been bout an hour or so, just been out to start it to put it away and it won't bloody start, there's nuffin, pump primes but won't even turn over, any1 have a clue what could be up with it?????
Oct 9, 2015 07:38 PM
jamie956
11
Aug 25, 2015 11:51 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
lockie
Jul 31, 2015 10:03 PM
