Zetec Turbo...What Turbo??
Jun 28, 2010 | 05:51 PM
Currently building a Zetec Turbo for the Escort RST.
Looking for around the 300hp mark and not sure what turbo to use? Spec of the rest of engine is steel bottom end, std head (uprated valve springs), EFI inlet, running omex or similar and tubular exhaust manifold.
What turbo would be a good choice?
Jun 28, 2010 | 06:01 PM
I am using a Cosworth T34
Brian
Jun 28, 2010 | 06:05 PM
What exhaust manifold you using mate?
And does it fit differently to the exhaust compaired to the std T3 on a escort?
Jun 28, 2010 | 06:18 PM
A gt28 would be a good turbo, that's what ime using on mine and it's a very good turbo
Jun 28, 2010 | 06:26 PM
Quote:
Originally Posted by
robp-tt
the gt28 is a great turbo , but you need to know what power you want and spec it from that.
a gt2860 is what i would go for if you only want 300hp and a fast spool! or on the cheap a t34.48 wont be far off it on spool
Jun 28, 2010 | 06:28 PM
Whats the most you could safely expect from a T3 on a ZT?
Jun 28, 2010 | 06:29 PM
mattseries2
Will be getting a custom one made so the Turbo sits over the gearbox
Brian
Jun 28, 2010 | 06:30 PM
lozi
270-280 at a push i would think but it would need to be a cossie t3 not the small escort rst one lol.
Jun 28, 2010 | 06:31 PM
Where can you get the gt28 from? And what exhaust manifold and exhaust fitments would i need?
robnock
21
May 13, 2019 05:29 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
