vw bora back passenger door wont open..
Old Jun 20, 2010 | 02:47 PM
andy130's Avatar
andy130
Default vw bora back passenger door wont open..
from the inside or the out side, someone must have pulled the outside handle out of place as you can tell its not in place etc, i took the door card etc off an try opening it from there an i still wont open, has any had or fix this problem before? cheers andy
Old Jun 20, 2010 | 03:10 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
Only thing you can do is pull the latch apart and fit a new one
Old Jun 20, 2010 | 03:56 PM
andy130's Avatar
andy130
tried opening the door, cant get it open at all, tried everthing it seems the latch is stuck on
is there another way of getting it open?
cheers
Old Jun 20, 2010 | 03:59 PM
NoRubNoDub's Avatar
NoRubNoDub
Break the latch apart with a small pry bar
Old Jun 20, 2010 | 04:08 PM
andy130's Avatar
andy130
cant get near it hardly mate,
Old Jun 20, 2010 | 04:21 PM
ford addict's Avatar
ford addict
hi mate the locks on these cars and similar like skoda octavias tend to jam and the only solution is to break the lock by removing the weather strips and by means of a bar and hammer break the central lock mechanism
Old Jun 20, 2010 | 04:23 PM
vaughant's Avatar
vaughant
Take it you've tried locking/unlocking the door several times from the key/fob as it sounds to me like it's deadlocked itself.spray a load of wd40 into the lock mech as if they don't get used much they sieze up.only other solution is unfortunatley to force it somehow.have a look on the opposite side door to see how the catch is held in,usually two torx bolts,you maybe able to get behind it too see where the fixings go and possibly grind or tap out the receptors.try to restrict the damage to the door as it will be far cheaper to repair then damage to the inner arch.good luck mate.
Old Jun 20, 2010 | 04:24 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
try harded . ive had to do this on a few vw's now
cossiegreg1's Avatar
cossiegreg1
disconnect battery for 10 min. then reconnect. press central locking button, should do the trick
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
no1trancefan
Ford Focus ST
Aug 6, 2015 05:09 PM
