vw bora back passenger door wont open..
from the inside or the out side, someone must have pulled the outside handle out of place as you can tell its not in place etc, i took the door card etc off an try opening it from there an i still wont open, has any had or fix this problem before? cheers andy
hi mate the locks on these cars and similar like skoda octavias tend to jam and the only solution is to break the lock by removing the weather strips and by means of a bar and hammer break the central lock mechanism
Take it you've tried locking/unlocking the door several times from the key/fob as it sounds to me like it's deadlocked itself.spray a load of wd40 into the lock mech as if they don't get used much they sieze up.only other solution is unfortunatley to force it somehow.have a look on the opposite side door to see how the catch is held in,usually two torx bolts,you maybe able to get behind it too see where the fixings go and possibly grind or tap out the receptors.try to restrict the damage to the door as it will be far cheaper to repair then damage to the inner arch.good luck mate.
jessie_rs
11
03-06-2019 04:57 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
