duratec v6, good or bad??
Old Jun 14, 2010 | 03:45 PM
tincho84ar's Avatar
tincho84ar
Default duratec v6, good or bad??
Hi everyone, I'm looking for a shell to build a cossie looks, 3 door sierra and a possible engine that I can buy is a duratec v6 from a mondeo, does anybody knows this engine?? is it possible to fit in a sierra? thanks..
Old Jun 14, 2010 | 10:14 PM
cjwood555's Avatar
cjwood555
It'd be easier to use a cossy v6 boa/bob - engine mounts/subframes already exist, it's already design for RWD, and has better output and economy.
Chris
Old Jun 14, 2010 | 11:30 PM
tincho84ar's Avatar
tincho84ar
thanks, but around here all I can get are pintos engines (1.6, 2.0, 2.3) , and zetec or duratec v6 or 4 cyl...
Old Jun 14, 2010 | 11:35 PM
m4tt274's Avatar
m4tt274
surely you can find a granada cosworth??
but that would be a better option, problem with the duratec is its mounts are for FWD and a sierra is as im sure u know Rwd, so u would need to make weird engine mounts and a custom bellhousing.
built a pinto turbo, or import a BOA/YB cosworth motor
Old Jun 14, 2010 | 11:39 PM
Fiddy's Avatar
Fiddy
Duratec 2.5 V6 engines are pretty bulletproof. aslong as you keep the oil filled up to max, or just over, as they do like to spin shells at high revs, when cornering and the oil isnt full. also they have been known to pop headgaskets, and the plastic impellar water pump on the earlier engines was known to fail, not so much a problem on the later engines. bar that, they go on forever
Old Jun 14, 2010 | 11:43 PM
tincho84ar's Avatar
tincho84ar
have you got any idea of the shipment cost of a cylinder head, because, it may be an option, to get a 2.0 from a taunus and try to build a cosworth.
Any cosworth at all are impossible to get around here (v6 or 4 cyl)
Thanks a lot averyone for your help..
Old Jun 15, 2010 | 12:00 AM
m4tt274's Avatar
m4tt274
the pinto has same block as YB but pretty much everything is different.
not a clue on price for shipment but they are a heavy lump
Old Jun 15, 2010 | 01:06 AM
tincho84ar's Avatar
tincho84ar
is there any store, where can ask? someone who usually sales cosworth engine parts? thanks again, all the help is really usefull to me
Old Jun 15, 2010 | 01:22 AM
diegorji's Avatar
diegorji
Duratec is a reliable engine.Will not regret it.
Old Jun 15, 2010 | 01:08 PM
tincho84ar's Avatar
tincho84ar
thanks everyone, I think I'll be installing the duratec v6
Old Jun 15, 2010 | 04:49 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
there is a guy stateside who has put one of these into a merkur xr4ti - worth searching for
Old Jun 15, 2010 | 05:57 PM
Not a bad engine.
Old Jun 15, 2010 | 10:04 PM
DazC's Avatar
DazC
The ST220 Duratec engine is half of the Aston Martin V12. They are identical in design apart from one is twice as long! Bit of useless info for you!
Old Jun 16, 2010 | 10:50 AM
percybigun's Avatar
percybigun
Twistin me melon man
get one from a mk3 mondeo, the old mk1 and mk2 mondeo 2.5 v6's weren't that good tbh. fairly low power for a very heavy engine, very few aftermarket performance parts available, dodgy water pumps, head gaskets and bottom end.
barge and pole springs to mind!
i've been on the mondeo forums for 8 years and seen literally hundreds of threads about them knacking up.
a top end rebuild done DIY costs over Ł800 with all the right bits, a guy on our forum done one recently.
"bulletproof" pmsl!
Old Jun 16, 2010 | 10:52 AM
The Youth.'s Avatar
The Youth.
mine wasn't bullet proof in my st200, the timing chain tensioners failed and grenaded the engine
steve
Old Jun 16, 2010 | 11:13 AM
tincho84ar's Avatar
tincho84ar
haha nothing is useless, anyway, I hope to find the last v6, if not, I'll start import of cossie engine parts, It'll be expesive
Old Jun 17, 2010 | 01:44 AM
tincho84ar's Avatar
tincho84ar
what about the volvo 2.5 turbo engine, the one that comes on the last mondeo?? is it good, reliable, i would install it standard..
Old Jun 17, 2010 | 06:09 AM
cjwood555's Avatar
cjwood555
The T5 is a fantastic engine - get an actual volvo one, rather than the mondy-spec version and it's cheap too!
Old Jun 17, 2010 | 05:30 PM
tincho84ar's Avatar
tincho84ar
Engine mounts are too dificult to build?? anyone has done it before? I have been watching some videos of the new focus rs and that thing sounds awsome..
Old Feb 13, 2021 | 12:13 AM
Preggieg's Avatar
Preggieg
Default 3.0 duratec V6
Hey mate...how r uHow's it going with Ur install
Old Feb 13, 2021 | 09:01 AM
big_wasa's Avatar
big_wasa
It’s a very old thread
A few people are fitting them to things now. There are a few in kitcars. More usually the jag version the Aj30 as they are very cheap and easier to find over here.
The Rx8 gearbox being the go to gearbox.
One guy has a Duratec30 in a metro and is running 500bhp.
mine
haadee
Jul 23, 2010 05:20 PM
MJC
Sep 8, 2009 06:01 PM
sierra_2008
Oct 3, 2008 06:04 PM
Lowson
Aug 13, 2008 11:31 AM
damo86
Jul 29, 2008 10:56 PM
