Removing a/c, any help?
Old Jun 12, 2010 | 10:11 AM
duderacing's Avatar
duderacing
Default Removing a/c, any help?
The a/c on my 1.8 isn't working, probably due to it needing a re-gas, but I'm not really a fan anyway, so I'm looking into removing the system to get rid of the weight of the unit and any drive losses.
Tried to find previous posts on this, but found nothing.
Any body done this who can tell me what's involved?
Not sure if a silver top non-a/c ancilliary belt will fit.
Old Jun 12, 2010 | 08:19 PM
RichieST's Avatar
RichieST
You'll need to get any gas removed from the system by a pro, after thats done should just be a case of unbolting it all and fitting a belt from a non p/s zetec. Do you really need to remove it anyway? There is no drive losses when your not using it anyway...
Old Jun 12, 2010 | 08:24 PM
rsfido_1989's Avatar
rsfido_1989
its all of 40quid for a re gas
Old Jun 13, 2010 | 12:16 PM
duderacing's Avatar
duderacing
I'm not sure what is still driven when it's not switched on, but there will still be a loss, and if it's anything like the unit I re-fitted to an old bristol on work experience, it'll weigh a tonne, mounted quite far in front of the front wheels.
I didn't think it would be as cheap as Ł40 for a re-gas, but it's still money I could spend on somethin I want.
Old Jun 13, 2010 | 02:08 PM
rsfido_1989
yes but your gonna piss more away getting it removed adapting the car, thats more money that you could be spending on toys. it was the best 40quid i spent on my focus.
Old Jun 13, 2010 | 02:13 PM
duderacing's Avatar
duderacing
It needs a new belt anyway, and I never use a/c anyway. Can't see how I'll be spending any more money than I would anyway.
Cheers for the fb by the way.
Old Jun 13, 2010 | 02:18 PM
focusjohn's Avatar
focusjohn
St.
Ive done this on a mondeo before. Mine was empty of gas but i have also done it before by disconnecting pipes and running like foook although not recommended. Once you have removed the pump ussaly 4 bolts all you need is a non air con belt once thats on remove as much pipes as you like and the a/c rad if you want. I got my belt from local motor factors for Ł6ish.
Old Jun 13, 2010 | 02:37 PM
duderacing's Avatar
duderacing
Great, cheers John.
Did you notice any difference, how heavy was the unit, and what belt did you use? Was thinking one from a silver top, as all the zetec focus' have a/c.
Old Jun 13, 2010 | 02:46 PM
botters's Avatar
botters
competant bodger
you would be lucky if you saved 10 kilo not worth the effort really unless its a race car
Old Jun 13, 2010 | 02:47 PM
botters's Avatar
botters
competant bodger
plus above 30mph using aircon uses less fuel than having your windows down
Old Jun 13, 2010 | 04:01 PM
RichieST's Avatar
RichieST
Illegal too
Old Jun 13, 2010 | 10:03 PM
focusjohn's Avatar
focusjohn
St.
Originally Posted by duderacing
Great, cheers John.
Unit was 15kgs max tbh it isnt really worth the effort. Dont know about belt because off pulley sizes my be different on focus's compared to mondeos.
Originally Posted by Rich170
Illegal too
There a crime squad for it? Its only a few million cfc's?
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
