Focus ST - Fitting an Auto Dim Mirror
Old May 26, 2010 | 07:29 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Default Focus ST - Fitting an Auto Dim Mirror
Hi all,
Ive recently purchased an auto dimming mirror off eBay to fit to my Focus ST3 2007 (Non auto wipers). Its from a 2001 - 2003 Mondeo so the mounting bracket is the same as mine.
All I need to confirm is, what wires do I join the 2 from the mirror to in the back of my submarine light ?
Was going to join black to black for the earth then green/red (mirror) to the yellow/brown (sub light).
These are the 2 wires i'd join too /\
The mirror will work when the side lights are on and hence the sub light is on.
Thanks
Andy
Old May 27, 2010 | 05:38 PM
RichieST's Avatar
RichieST
Not sure mate but mine's also got a feed from the reverse light switch so if its dimmed then it un-dims when you select reverse.
Also that isn't how mine works, mine is activated by ignition i suppose, then it only dims when light is shined on the sensor on the front of the mirror.
Old May 29, 2010 | 10:52 AM
thebigmacmoomin
Was yours an option on the car when you bought it? Mine just had a normal mirror, but I missed it from my ST TDCi.
Can anybody else help?
Old May 29, 2010 | 10:55 AM
fiestamad's Avatar
fiestamad
i thought they came with them
Old May 30, 2010 | 03:21 PM
thebigmacmoomin
No, its part of one of the option packs.
Old May 30, 2010 | 08:52 PM
RichieST's Avatar
RichieST
Yes mines standard fit. It also doesn't have any of the buttons on the front that yours has!
To be honest, I find its a bit of a pain in the arse. If its dark and I want to see if the car behind is a copper or anything then its impossible. Would rather have a normal mirror sometimes!
Old May 31, 2010 | 11:41 AM
thebigmacmoomin
The one I had in the Mondeo didnt have any buttons either, this one is just an older version I guess. If its on, I suppose you just press the button and it turns off.
Old May 31, 2010 | 06:42 PM
Normally on fords black is a switched LIVE not earth, these are brown, though wiring wise they have been up to allsorts last few years so may be different now ?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
kosienutter
31
Aug 22, 2015 09:55 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
