Rs turbo shaking steering and almost everything renewed.
Old May 21, 2010 | 06:33 PM
Antti O's Avatar
Antti O
Default Rs turbo shaking steering and almost everything renewed.
Basic problem is that when i drive motorway speeds car shakes so badly even that steering column shakes up/down and it feels badly in steering wheel. Altough car does not shake when braking.. (miracle in rs turbo).
Normal driving shaking is so bad that i can feel it in the car chassis when put hand in the dashboard or something and everything vibrates.
Shaking is different depending day, sometimes almost nothing and sometimes so horrible you cant drive car cos everything shakes.
2 different sets of wheels tested, different combinations. Nothing help.
There is slight play in the steering rack and it makes klonking noise when quick turn steering in place.. There is old parts only the steering rack and those parts where bearings are installed , i dont know word for english.
New parts front
-Koni sport shocks
-H&R Springs
-Wheel bearings
-Front hubs
-TCA´s & ball joints
-all steering joints
-Brake discs
-Brake hoses
-Brake pads
-Steering rack rubbers
-Powerflex bushes all front
Ps. i think my car would go to shed under the blanket for several years if i dont find out what causes that. I am pretty finished with this thing.
Old May 21, 2010 | 06:55 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
did you check the plastic item(i don't know how to tell it in english...)between frnt alloy rims and hubs? If these doesn't fit exactly, car is shaking like crazy...
Old May 21, 2010 | 06:59 PM
botters's Avatar
botters
competant bodger
if its got play in the steering rack then it will shake
Old May 21, 2010 | 07:02 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i was going to suggest steering rack.
my xr2 is suffering a little with this, may just be a slight buckle in an alloy, if not then rack out and change for a new one
Old May 21, 2010 | 07:03 PM
Ginger Will's Avatar
Ginger Will
cv joints? do the drive shafts have play?
The car in m avatar had steering rack play and was as smooth as silk in a straight line.
Old May 21, 2010 | 07:07 PM
tomS2-Rst's Avatar
tomS2-Rst
Does it shake all the time at this speed? or is it on load ect.
Old May 21, 2010 | 07:08 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
power steering numbs most wobbles though, on non PAS cars this becomes more noticeable.
Old May 21, 2010 | 07:12 PM
botters's Avatar
botters
competant bodger
my steering rack on my s2 had slight play and it shook like fook! so put a new one on it was the best £20 ive ever spent it no longer shakes and the steering is so much lighter than it was before as well
Old May 21, 2010 | 07:27 PM
Ginger Will
Hairy Muff.
"my steering rack on my s2 had slight play and it shook like fook! so put a new one on it was the best £20 ive ever spent it no longer shakes and the steering is so much lighter than it was before as well"
Well worth £20 after the list of stuff above
Old May 21, 2010 | 09:06 PM
Antti O's Avatar
Antti O
Many thanks mates! My steering rack has really bad "play".. it makes klonking sound when turn steering wheel quickly in opposite directions. Car shakes wheels in the corners and in the straight, basically no matter if there is throttle or not or gear in or not. Whole car chassis shakes and car is really bad drive in corners. Maybe one of the worst cars ever which i have driven. So maybe its time to buy patten steering rack for 79€, i have to order it from Germany. I think the driveshafts are okay.. there is no play or extra noices. Now i have working LSD unit and car has about 270bhp and it pulls really badly left / right and it is real struggle to keep it straight line, without lsd it went pretty straight is this normal? =)
Old May 21, 2010 | 10:36 PM
morph's Avatar
morph
mate i can get you a ford rack fully refurbed and it will be most likely much better than the pattern racks you get as i had the same thing with mine and i ended up replacing twice!
let me know if you want one.
Old May 21, 2010 | 10:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes this is normal, LSD transfers torque to the other wheel when one looses traction and then back again causing torque steer, my Quaife ATB LSD was even worse than a norm RST LSD for this!
Old May 22, 2010 | 06:56 AM
Antti O's Avatar
Antti O
Hi
yep, i would be interested original steering rack but my rs turbo is lhd version.. Can you help?
Karlos: Okay.. it feels pretty wild to drive, maybe i decrease my maximum boost... so it would be less scary.
Old May 22, 2010 | 10:14 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Bush at the bottom of the column.
Noone ever checks these and always crack in half when people change steering wheels etc.
Make sure its in good condition.
The way to test is if you can pull the steering wheel towards you when sitting in the drivers seat then its foooked. . Taking it out is not hard and should be looked at!!!
Old May 22, 2010 | 11:14 AM
morph's Avatar
morph
Hi
i could tell you if they are different to lhd or rhd
Old May 22, 2010 | 08:13 PM
Rob_DOHC's Avatar
Rob_DOHC
??? what? of course they are different you plank the steering wheel is on the other side of the car lol
And Jano i was about to suggest the same think, the column has several bushes up its length. My car had the exact same problem, and when i took the column out all the bushed/bearings were awful. But if you have play in the rack there is no harm in changing that first!
Good luck
Rob,
Old May 23, 2010 | 08:44 AM
Antti O's Avatar
Antti O
Rob:
All those plastic bushes, wearing parts are pretty new in the column. Only the steering knuckle joint is old because i cant find new part anywhere. Ford sells only the whole axle including the joint.
Old May 23, 2010 | 12:32 PM
morph's Avatar
morph
Rob:
i will see if the steering knuckle is available and if yours is a genuine ford rack then you may want to send that off to get refurbed as the pattern ones are sometimes not that great. if you cant get it refurbed over where you live then send it over here and i will get one in fact i will ask if i can get the lhd rack.
Old May 23, 2010 | 12:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Classic post!
Old May 23, 2010 | 05:59 PM
Antti O's Avatar
Antti O
Many thanks... post here then or pm
Old May 23, 2010 | 06:07 PM
aronzvh's Avatar
aronzvh
Mine shaked on motorway speeds but luckily it was jus due to tracking being out,!
Old May 24, 2010 | 02:24 AM
morph's Avatar
morph
Originally Posted by Karlos G
Classic post!
Well some cars use the same rack both sides so that seems classic? But I suppose your not bothered abt that.
Old May 24, 2010 | 10:08 AM
JesseT's Avatar
JesseT
Even if it would fit in, the car would steer left when the wheel is turned CW and vise versa.
Old May 24, 2010 | 10:20 AM
Rob_DOHC's Avatar
Rob_DOHC
*re post*
Old May 24, 2010 | 10:21 AM
Rob_DOHC's Avatar
Rob_DOHC
Rob:
Hmmmm... The knuckle is very easy to check for play, just get some one to rock the steering whilst you feel the joint. I would probably fit a cheap rack and see if thats the problem (they are easy to change) and if that does fix it look for a genuine ford one later.
JesseT, I wouldn't bother explaining it to him mate, he probably hasn't learnt his left and rights yet any how. But yes morph, think before you speak, instead of just letting your brain vomit into your mouth.
Rob,
Old May 24, 2010 | 05:19 PM
morph's Avatar
morph
Jesse cheers, My mistake should know everything about rst's!
Old May 24, 2010 | 06:41 PM
Rob_DOHC's Avatar
Rob_DOHC
Because he's built so many.
Old May 24, 2010 | 07:05 PM
morph's Avatar
morph
Antti O, sorry for the thread crapping going on mate, its got nothing to do with your problem, but some peeps dont get that!
i have asked the supplier if he can sort out a rack for your car.
he will let me know sometime tomorrow so will get you cost and postage you may not need to send your rack over either.
Old May 24, 2010 | 08:06 PM
Rob_DOHC's Avatar
Rob_DOHC
How very kind of you to apologise on behalf of me Morph.
Any luck with fixing it Antti? Got me thinking i may need a new rack too, Fancy giving me a quote Morph..... that would be for a RHD. Who is your supplier by the way? its not www.itakefordracksandfuckthem.com is it?
Rob,
Old May 24, 2010 | 10:43 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Rob,
PMSL
Old May 25, 2010 | 07:07 AM
Antti O's Avatar
Antti O
I got replacement steering rack yesterday and i can test it before paying. So i today will change that rack and then write some comments. We will also weight wheels once more.. that has been done then 4 times with 2 different weighting machines.
Old May 26, 2010 | 04:43 AM
Antti O's Avatar
Antti O
Some good news
My current steering rack was only tightened and that play in the rack is now gone. Wheels were balanced with very good balancing machine, only 5-10g weights / wheel. Steering angles was adjusted too. I think that vibrations are now pretty much gone what i drove yesterday 10kilometres it felt fine. There is still play in the steering wheel axle joint, any ideas where those parts can be bought? Ford sells whole axle and it is not cheap..
Another thing which i noticed there is pretty much play in gear change joints, are there some kind of uprated solution or repair kit available?
Old May 26, 2010 | 08:37 AM
morph's Avatar
morph
You can do a DIY fix on the rod by replacing the bolt that holds the rod in place, its not too difficult to do just make sure the nut and bolt used are good quality either stainless or zinc plated and lock nut.
Old May 29, 2010 | 07:12 PM
morph's Avatar
morph
i sometimes have this problem like you describe able to pull the steering wheel out by about 1" or so but only sometimes, is this the bush that should be holding the coluom and the joint in place? any pics would be great and where can you get the bush from plz?
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
Mark Mawson
Aug 31, 2015 07:09 PM
Sheepdisease
Aug 30, 2015 09:11 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
