GT28 Range...
Old May 7, 2010 | 08:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default GT28 Range...
They spool faster being BB and presumably flow better being a much more modern design than our T3's....
So which of the GT28 range of turbo's is the best alternative to a Stage 3 T3 and why?
What is required to fit one to a RST manifold?
What i'm looking for is something that will respond as well as my Stage 2 T3, but with a less restrictive exhaust housing (to keep temps down a bit) and that's not right on it's limit all the time.
What I dont want is a turbo that will flow for 400bhp and not make boost untill 5000rpm! lol
I have no experience with these so all info is appreciated!
Cheers!
Old May 7, 2010 | 08:15 PM
12_Second_rst's Avatar
12_Second_rst
All them are quite big I'm sure they do 1 smaller than the 71r don't mark my word tho
Old May 7, 2010 | 08:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah they do... the GT28RS aka 'The Disco Potato' but it will only flow for 250bhp and thats on a 1800cc so is no good to me.... At least thats what is says on the Garrett site!
Old May 7, 2010 | 08:35 PM
lead_foot's Avatar
lead_foot
is awesome
More than that! A GT28RS(.82) will max out around 370 but will make full boost by 2.8-3k on a 2000cc.
Old May 7, 2010 | 08:39 PM
jaiscossie's Avatar
jaiscossie
My gt30 comes in about 2.8k so must be very similar when it comes in
Old May 7, 2010 | 09:08 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Karl,
The BB thing is not quite as exciting as some would have you believe. I ran the GT28RS for a while, it's a REALLY nice turbo. It will do the high end of 200bhp and be lively. But lets not be unrealistic here, it won't be super responsive, just a little better than a T34 0.48, but not much.
Jai - I presume you start making boost at 2800? When do you have full boost?
Old May 7, 2010 | 09:21 PM
project rs's Avatar
project rs
when you say a little i persume your talking 500 revs or so
Old May 7, 2010 | 09:23 PM
Christian and Beccy
#1 in Spelling Club
If that to be honest.
Old May 7, 2010 | 10:13 PM
rsmark86's Avatar
rsmark86
Originally Posted by Christian and Beccy
Karl,
well i want the t34.48 as its a faction of the price and nearly as good anyway..... my mates one was on his cossie doing 360bhp at 32psi mapped by karl norris so will be ample on my little 1600cvh
Old May 7, 2010 | 10:40 PM
Christian and Beccy
#1 in Spelling Club
T34 0.48 can just about do 300bhp on an RST.
Don't go for the bigger housing though!!
Old May 7, 2010 | 10:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
hmmm... Maybe i'll just stay as I am, dont want to loose my drivability!
If the GT28RS is only slighty better than a T34 .48, then it must be similar to a Stage 3 T3.......... which for me is too laggy.
I know project rs you say your T34 isnt laggy compared to a stock T3 but I dont have your manifolds, which seem to make a huge difference!
Old May 7, 2010 | 10:55 PM
rsmark86's Avatar
rsmark86
thats cool as i want you cam kit and one of these turbos and an ava manifold if i can find one when money is in my pocket lol or just a jamsport one although the one on your old car was stunning asweel and i would be happy with around 270/280bhp i think that would be immence in a s1 .....
Old May 7, 2010 | 10:58 PM
rsmark86's Avatar
rsmark86
thats why im saving for a manifold before i put a bigger turbo on but seems a shame as ive got a stage 3 t3 and a autospecialists manifold thats brand new and only done a trip to the mot station 1.5 miles from my house lol.....
Old May 7, 2010 | 11:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
This is the sort of response I have right now, 14.7psi @ 2871rpm and 27.2psi @ 3250rpm...
I have bucket loads of midrange power and then it tails off to about 21psi by 6900rpm, such a drivable power curve that I dont really want to lose!
Although it doesnt spool quite so fast with this XR3i gearbox in as it did with the XR2 final drive ratio.
Old May 7, 2010 | 11:13 PM
rsmark86's Avatar
rsmark86
sounds like a lovely spec mate well mine is a bit like yours just with a stage3 and big inlet .... but on greens and gotech... might put in my greys as then i can run 28psi lol
Old May 7, 2010 | 11:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah I think i'll just stay as I am, I already have 3 broken gearbox's under my belt as it is!
Old May 7, 2010 | 11:28 PM
Neil@FastFord's Avatar
Neil@FastFord
Yep, seems like you are trying to cure a problem that doesn't exsist mate. Keep it, fix it when it dies.
Old May 7, 2010 | 11:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Well i was a little concerned about head temps (after dropping a valve seat back in November) and a bigger exhaust housing would help..... or running less boost
Old May 7, 2010 | 11:37 PM
Neil@FastFord
Was temps the cause of the failure?
I'd be looking at coolers, coolants, rads, airflow.
That turbo shouldn't be giving you too much grief. And for me i'd be on a Stage 3 T3 or 4x4 Cossie T3 as a sensible cost effective step up if you need to.
Old May 8, 2010 | 08:27 AM
crazycage's Avatar
crazycage
last week you were trying to tell me that the gt2871.86 trim 56 would never do 400hp on any zetec !! even tho i have just pushed one to over that on my own car, this week you are saying the smaller gt2860rs will do 370hp strange.
Old May 8, 2010 | 08:29 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Big mystery really mate never really found out with 100% certainty, but running a .36 housing to it's limit creates loads of heat how ever you look at it, which is always bad!
My coolant never gets over about 95deg even when being thrashed, and my ACT's around 35deg (ambient temp of 25deg) so the whole engine runs nice and cool.
But without meassuring EGT's you never really know what your cylinder temps are like, would just be nice to know things are as safe as they can be.
Old May 8, 2010 | 08:40 AM
project rs's Avatar
project rs
what intercooler you running karlos and you really should get an egt guage in your car as you would hate to have the head of again and it looks like you need to play with the settings in your boost controller to sort those boost spikes out nice and smooth to start with then a bit wobbly but thats a nice curve
Old May 8, 2010 | 08:49 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Radtec mate, ACT's are fine i'm just trying to be ulta safe! lol
I guess you just drill the manifold and fit the sensor in there for an EGT gauge?
That graph is zoomed out to the max so it's not anywhere near as bad as it looks, it fluctautes by maybe 1-2psi, although I did find a leaking hose on the inlet manifold yesterday which wouldnt of helped!
15psi @ 2690rpm..
26psi @ 3137rpm
These are from my old gearbox and early maps (still had fuel to pull out and timing to add in) have not got any with my new box and injectors because of the noise problem using greys I have not been able to do anthing
But thats sorted now I have some high impedance injectors again!
Could you post up one of yours with the T34 on? I'd lke to see how thats making boost compared to my Stage 2 T3!!
Old May 8, 2010 | 09:22 AM
Rick's Avatar
Rick
lag/boost threshold/lag boost threhold/lag.....
Old May 8, 2010 | 09:24 AM
Karlos G's Avatar
Karlos G
Balls Deep!
What do you mean? lol
The T34?
Old May 8, 2010 | 12:17 PM
Rick's Avatar
Rick
Karl, does your car feel revvy? My first engine ran a CVH35 on a Std head and a stage 2 T2 at 20psi. The power came in with a bang, but it loved to rev and i liked the way it drover. You will get much MUCH better response with a std cam. Your engine, along with my old one was a compromise. On your logs, you can see the torque is dropping off quite a bit at the top - cam you see how the RPM plot is becoming less steep?
You have a big head and cam, but then a small turbo which is choking it. Or, you have a small turbo and big head and cam which are making it make boost higher up. I know why you've done it, to try and have power and response - but you are ultimately just condensing the power band.
Rick.
Old May 8, 2010 | 01:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It does mate yes!
I've fucked about with standard cams (Ford and Pattern) and both have fallen apart very quickly so even if the profile is more suited to my setup it's not an option for me.
The power band to me feels really big, from about 2800rpm right through to 6500rpm'ish it pulls strong, will be interesting to see the actual torque curve when it's dyno'd.
If you look at my VE table it really drops after about 6500rpm, i've actually moved the limiter from 7050rpm to 6800rpm now as there was no point having it that high if the engine isnt breathing.
Old May 8, 2010 | 02:19 PM
Rob_DOHC's Avatar
Rob_DOHC
Karlos, i recently read about a ball bearing stage 3 t3 that apparently comes on boost nearly as well as a stage 2, Antti O on here has done a very nice TD03 turbo conversion which also seems to be a very nice compromise.
Rob,
Old May 8, 2010 | 07:31 PM
rstdave's Avatar
rstdave
Karlos, as you've said your setup/powerband etc looks really good tbh and you seem happy with it! Be interesting to see what your egt's are so you could put your mind at rest as to how safe the setup is, then you can just enjoy it till the turbo dies lol.
After finally sorting some springs and having some time mine will be back in for round 2 of mapping so i'll let you know how it goes as mine is on a stage 3 t3. But running the bar of boost it currently is i'm really pleased with how it makes boost (a little later than yours i'd say but full boost by 3.5k roughly i'd say) but too early to say how good it will be.
Unfortunately the bigger turbo's that continue to make more power at the top on our little cvh's will inevitably be laggy to a point but that's the decision you've got to make.
A friend of mine is trying a fairly 'different' turbo on his 1.6 and isn't far off being ready now which could be very interesting if it does what we're hoping for
Old May 8, 2010 | 09:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate let me know how you get on!!
For me it is all about low/midrange response and as you can see I have plenty of that right now so going bigger probably wont happen, but EGT monitoring is on the cards for sure!
Your mate's sounds interesting.... tell me more!!!
Old May 8, 2010 | 10:14 PM
rstdave's Avatar
rstdave
I will indeed mate!!!
My mate's is all top secret lol (joke), we're trying an evo twin scroll turbo/manifold on his new engine as a bit of an experiment as a (cheap) alternative to the Gt range.
I've also got the initial parts to do the conversion but as you can imagine the physical fitment is a bit of a nightmare and i decided to let him try it first in the end lol and see how it fares.
The guy who does my mapping thinks it should work pretty well but obviously until it's been mapped we won't know and unfortunately it's not going on the engine dyno as planned so i won't see the graphical evidence i was hoping to
Old May 10, 2010 | 11:38 AM
wilky's Avatar
wilky
have a look at this for spool up time from wet bearing and ball bearing
http://www.jgstools.com/turbo/50vsgt40.jpg
i don't like ballbearing's they break easy i seen enought with snap shaft
a bit of spark plug coming off will damage the shaft and you wil need a new core
wear a old t3 you can replace the shaft which is cheaper
what a bout t28 from pulsar they the same as disco potato size
IAN RS2k
Aug 18, 2015 07:51 PM
Prospero
Jul 24, 2010 06:07 AM
ESCYSCOTT
40
Jun 26, 2005 07:05 PM
