whats the best cam choice for my car and spec
as above what cam would work the best with my spec and future mods.
full spec at the mo.
stage 3 big valve head
ported polished and cross matched inlet and adaptor plate
mk's old inlet plenum (field motorsport inlet)
efi fuel rail
dark green injectors
autospecialists tubular manifold
cr turbos stage 3 t3 hybrid
genuine ford gaskets and bolts
1600cvh bottom end
woszner low compression pistons
pec steel rods
arp bottom end bolts throughout
fully lightened and balanced crank and flywheel ect and tufridged crank
at the moment the cam im unsure of as i got the head complete but its got (4 85t) stamped on it
and im looking at a jamsport manifold and cossie turbo of a brian hansen manifold and gt28 not sure which yet
efi fuel rail
1600cvh bottom end
pec steel rods
you sure that isn't a 2 instead of a 4?
if it is then just stick with it. the ony real option is to change to a newmans cam and specify what you're after and they should be able to calculate something for your needs.
wicked well the cam does does have a 4 then a gap and 85t on it but i want to at some piont have a bigger turbo and around 280bhp and matching torque
the problem with the next cam up, in no regards to life expectancy, is that it is quite a laggy item, the 285T is a decent cam.
just give it more boost fella, but upgrade your injectors, IMO they won't get you fuelling right for that power level as myself has found out. (they're 390cc injectors, i'd reckon on 240bhp in an ideal well designed engine)
what would be a good choice
and forget to say the car is on gotech management
You'll want cossie dark blues for 250HP (iirc) there good enough for 250.
You want to run the duty cyclone around 70% at full boost,So you dont want a injector your having to push 100% as you'll burn it out.
Also dump the go-tech.
Cam choice would be a newman cam,
sorry i dont understand to much about injectors .....
I was just told by a tuner fella dark blues will fuel 240-50HP that's all i said as there's a debate over green's and i know about dark blues as i asked a tuner (A reptuable one)
Basically you can push a injector to the limit but how long will it last? Same a turbo a T3 running 25PSI but yet you could get a T3 STG3 and run 18PSI it's less stress etc.
An injector will burn out at 100% duty cyclone, You need to have the injector sat at 70% use at full power iirc (Ideally)
as on an escort cosworth the dark blues will do 280bhp and the dark greens will do 350bhp and thats with out pushing to hard as i had an escort cosworth built by nms on a live map and that was mapped at 30psi running around 365bhp and matching torque
...... thats why i find it confusing.
injectors on a cossie and an rst fuel differently, the cossie is more efficient and hence don't need as big injectors, similarly a zetec turbo is more efficient that a cvh, therefore less fuel needed per bhp.
the dark greens will fuel at that level, but how well and how much will they be pushed to achieve that is not known by me.
p.s. forget go-tech
p.s. forget go-tech
JoeyBoyden
Jan 4, 2024 02:36 PM
Roosie
Aug 13, 2015 07:40 PM
