Cold running problem
Old Mar 28, 2010 | 08:28 AM
cossie330's Avatar
cossie330
Default Cold running problem
hi, when I start my cos 4x4 from cold it starts fine but if I give it some throttle it stalls, its all ok when its been running for a couple of minutes, any ideas? I have changed all the sensors, although previous to that it has been stood for about 2 years
Cheers Jason
Old Mar 28, 2010 | 10:40 AM
martysmartie's Avatar
martysmartie
Have you checked (Cleaned and lubed) the ISCV as it may be this is stuck especially if it's been stood still. Have you replaced fuel filter? If you open throttle a bit when starting from cold does it run ok?
Martin
Old Mar 28, 2010 | 11:22 AM
cossie330's Avatar
cossie330
Hi it probaly needs a fuel filter as looks original, if I use very light throttle its ok
Old Mar 28, 2010 | 12:24 PM
So it's a mixture problem, what CO is it running is it chipped, what fuel pressure is it, all this needs checking, sounds just a little lean on cold running.
If the fuel filter is more than 2 years old replace it, bacteria grows well in it.
As the car sounds new to you ?, make sure the fuel pump and fan loom rewire have been done, for safety reasons.
Old Mar 28, 2010 | 08:27 PM
cossie330's Avatar
cossie330
Hi I have done a fan loom rewire but am going to do a fuel pump rewire loom and also replace the pump, is it a good idea to upgrade to an 044 pump, also its chipped to stage 3 but I think I shall change the spark plugs then when the bodywork is done get it booked in for a check up.
Cheers jason
Old Mar 29, 2010 | 01:05 PM
The 044 is only marginally better in flow terms than the 941 std pump, at stage 3 a std 941 is more than capable.
Get your filter and pump rewire done before getting it checked over, make sure you use new copper washers on the banjo's for pump/filter, about 50p each from ford.
kosienutter
31
Aug 22, 2015 09:55 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
Zoggon
Aug 10, 2015 10:39 AM
