41mm Socket - Where from?
Old Jan 10, 2005 | 12:00 PM
Neil S's Avatar
Neil S
Default 41mm Socket - Where from?
I need to undo the rear hub nuts on my cossie, and reckon that the nuts are 41mm.
So far so good, but I cant find anywhere that sells 'em!
Any ideas peeps?
Neil.
Old Jan 10, 2005 | 12:11 PM
SPADGE's Avatar
SPADGE
Halfords?
Old Jan 10, 2005 | 12:12 PM
Neil S's Avatar
Neil S
Nope - biggest they had was 32mm
Neil.
Old Jan 10, 2005 | 12:14 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Brown Brothers
Old Jan 10, 2005 | 12:16 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Lamberts in Norwich... .
Old Jan 10, 2005 | 12:18 PM
Neil S's Avatar
Neil S
Shut it Mike - Like you even OWN one lol
Mike R, proud owner of the only concourse socket set in existance
Now where's my price on those hoses?
Ill give Brown's a call - Cheers Adam
Neil.
Old Jan 10, 2005 | 12:20 PM
Mike Rainbird
Caraholic
Shows how much you remember , my socket set is probably the grubbiest known to man (you used it at the 'Ring remember ) .
I am waiting for a return email .
Old Jan 10, 2005 | 01:18 PM
Neil S's Avatar
Neil S
No joy yet - the only ones I can get are 3/4" drive, and I only have a 1/2" breaker bar
Neil.
Old Jan 10, 2005 | 01:46 PM
Mike Rainbird
Caraholic
Why don't you see if they have a ˝" to ž" convertor then you numpty .
Old Jan 10, 2005 | 02:02 PM
s1rscustom's Avatar
s1rscustom
i can get you one from work if need one still, pm me if you do
Old Jan 10, 2005 | 02:05 PM
Iain Mac's Avatar
Iain Mac
My local Halfords sells bigger sockets in imperial sizes.
Would 1 5/8ths be close enough, esp. one that grips the flats rather than the corners? Would be worth taking a spare nut down with you, just to be sure it will fit - these are supposed to be replaced anyway, so maybe get new ones from the Ford dealership then go to Halfords.
Old Jan 10, 2005 | 02:08 PM
Fil's Avatar
Fil
ELASTIC BAND
had the same problem, got one from an A1 motorspares place 3/4 tho then had a bit of 1/4 angle iron cut it stuck it in the socket and 1/2 drive now fits!
Old Jan 10, 2005 | 10:36 PM
Chris Reade's Avatar
Chris Reade
Cromwell Tools sell them in 3/4 or 1 inch drive according to the catalogue I have in front of me. Largest in 1/2 inch drive is 36mm.
www.cromwell-tools.co.uk
Part no ken-582-8300k for 3/4 version
Price 14.48 inc vat
Old Jan 10, 2005 | 10:38 PM
steviep's Avatar
steviep
try www.machinemart.co.uk
They sell everything
Old Jan 10, 2005 | 10:55 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
I think the rear hub nuts on a cossie are 42mm, don't use 1/2" drive as you will snap them like carrots, use min of 3/4" pref 1" drive if you can get them, machine mart are quite good for stuff like this or look through the yellow pages for local engineering merchants or tool suppliers oh and you will be needing a big fook-off extension as well, 4-6ft at a guess, a bit of old scaffolding does the job well
Old Jan 10, 2005 | 10:58 PM
Neil S's Avatar
Neil S
Cheers for all the replies!
Will - I have the scaffold pole lol
Think I'm gonna borrow one off the youth - failing that theres a Cromwells near my office so I'll nip over there
Thanks Again!
Neil.
Old Jan 10, 2005 | 11:00 PM
Graceland's Avatar
Graceland
Team HOTHOT!
draper do a 41mm impact socket with half inch drive - i got greedy and bought 2
Old Jan 10, 2005 | 11:38 PM
richm's Avatar
richm
http://www.sptools.co.uk/catalogue/i...keyword=socket
I'm pretty sure this is 1/2" drive, i can get a good price if u want me to find out?
If u want one local, Brown Brothers or Partco should do 'em
Old Jan 11, 2005 | 07:33 AM
Neil S's Avatar
Neil S
I rang Browns and they were bloody useless
I'll nip over to Partco at lunch - cheers Rich
Neil.
Old Jan 11, 2005 | 08:03 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: 41mm Socket - Where from?
Any ideas peeps?
Neil.
dont forget the one side is a l/h thread
Old Jan 11, 2005 | 08:47 AM
Neil S's Avatar
Neil S
Cheers Martin - I did suspect that it may be
That would have been really useful advice if you'd told me which side it was!!!!
Neil.
Old Jan 11, 2005 | 09:10 AM
richm's Avatar
richm
Neil.
u can tell by looking at the thread that hangs out beyond the nut..
oh, and the Sykes socket is 3/4" drive by the sound of it, and not as cheap as I remembered
Old Jan 11, 2005 | 10:04 AM
Thrush's Avatar
Thrush
Irritating c........
Phone these guys up;
01992 715 900
Company is called Group Componants, based near me, but 99% sure they do mail order....
They will have ANYTHING you need, and I know they will have the sockets as they have fucking HUGE sockets in their display cab (and when I mean HUGE i mean nearly a foot in diameter )
Also they will be cheaper than ANYWHERE else, specially Cromwells, Halfords, Partco, Browns etc.... Even inc postage they will be cheaper
Old Jan 11, 2005 | 10:15 AM
RichardPON's Avatar
RichardPON
PMSL @ the image of Neil hanging off the scaff bar screaming, "it wont undo!"
Old Jan 11, 2005 | 11:22 AM
wes's Avatar
wes
Neil.
Passenger side
Si B
Sep 12, 2015 06:49 AM
rst-s1
Aug 23, 2015 07:56 AM
SPADGE
25
Oct 20, 2005 08:51 PM
the strut brace
11
Jul 17, 2005 08:56 PM
