Telephone sockets and Broadband Q?
Having had loads of grief from poxy Wanadoo regarding their 'live boxes' which don't work and their staff that are fooking useless piss takers
I'm thinking that it may be a better option to put a phone socket in my office so i can use the comp online in there.
Is it ok to run a socket using the usual wire etc...to the other side of the house when on 2 meg broadband? Or do i need some special wire and socket etc...???
Cheers Spadge...
Cheers Spadge...
If you have a phone downstairs you will need to get a double plug! Plug the extension into one port and then a filter into the other one! Plus the phone into the filter and job done
Then upstairs plug a filter into the extension and the modem / router into the filter!
Any problems then feel free to contact me
i think if you use a master socket with the capacitor it needs wiring up different, but im sure you can cut out the capacitor and just jumper the wires straight off the original socket on terminals 2 and 5.
the phone wont ring but if it is just for the pc it will be fine with a filter
im sure some 1 will know for deffinate on here tho
Team HOTHOT!
i routed cat-5 network cable direct from the box on the wall where the phoneline comes into the house to where my router is - aint had any problems at all at this end
The maximum distance using any cable from the main phone point is 10 metres, so if you loop of an existing phone point and relocate to another room the cabling must be withing 10 metres to the modem. Some people do go further than this with no problems other get reduced speed or connection droping.
My broadband filters only work off the main socket, ive tried running them from another extension in the house and the signal isnt strong enough. Not sure if you'll have this problem too or not Spadge.
just rememeber EVERY sockey in the house you have a phone needs a filter
not ALL extension leads have all wires punched down, hence some will work and other wont.
cat-5e would be the best option, but that's not quite as easy to do as telephone unless you know people in IT
hope that helps
hope that helps
i can give you the colour codes for the cat 5 cabling if needed
thats if you want to connect directly to a router or cable box
i have plenty of cat 5 cable if you wont some sending to you
spadge, time to pay back a favour :P
i can get u any size cat 5 cable u want, cut to length, and terminated both ends if u want. max length 305m, as thats how much cable is in the boxes :P
you COULD couple it if u want, but not sure if u would want longer than 305m anyway and over 120metres you get signal loss and would need a hub inbetween anyway
Thanks for all your advice and help people
This cable would have to go all around the house to get to my new office and so would be at least 25-30 metres!
Just got off the phone to Wanadoo and they are sending me live box number 3 Hope this fooker works better than the 1st 2 which lasted 10 mins each
If that goes pear shaped then i'm moving lol
Pissing myself at 305m i live in Milton Keynes not fuggin Balmoral mate
Originally Posted by Chrissy_bwoy
spadge if ya need any advice etc gimme a shout, its me day job
If its the latter how about shooting over and putting me a decent socket in If its the former how about shooting your work coleagues
Originally Posted by RS Bowk
any1 know where the cheapest place is 2 buy the broadband filter from for ur fone line as i need 2 more?
line
Just get some 8 wire, run it through the house, conect a secondary socket to it, Blue to 2, White of blue to 5, orange to 3, and a filter in the end, will be fine for what you want, I do it every day, (BT),
Not sure that you have read my posts on here properly mate but i have had 2 wireless box's from Wanadoo so far that died and am now waiting for the 3rd! The hard wiring is just a back-up plan in case this box goes tits-up as well
so wot filters do peeps recommend as the 2 i got with wannado are fine but dont wanna pay the earth 4 2 more.lol
Si B
12-09-2015 06:49 AM
