HID's in latest shape focus (plastic headlights)
Hi can anybody tell me if after market HID kits are ok in the latest shape focus's as im worryed about the plastic headlights, I have fitted them in my range rover over a year ago and no really hate driving the focus at night.
HID tend to run much cooler using less power than normal bulbs. They are legal to use if you have a clear projector type lens not the normal refracted lens which changes beam pattern you find HID into normal lens will blind oncomming traffic regardess how you aim the head lamps hence illegal or mot failure.
I ran them on an old focus and I put them in a mondeo too. Failed the MOT both times as there was no beam pattern. Also needed to rewire the lights on the mondeo with heavier relays/fuses as the start up current they draw was blowing fuses knocking out the relays! This was an expensive kit at the time too.
Far more hassle than they were worth, and no brighter than a decent set of halogen bulbs.
I disagree on the halogen bulbs being as good as hids i had an expensive set in my sierra and thought they were good when new about after a while they seemed no worse than standard bulbs o i got used to them.
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
