Headgasket
Old Mar 13, 2010 | 04:14 PM
tarry500's Avatar
tarry500
Default Headgasket
Hi all, I need a new head gasket for a 2litre silvertop Zetec, is one from Ford good enough or is there better for the money, not looking for anything fancy just reliable. I think the last one has gone after only 5k, i was stuck in traffic and when it cleared it was misfiring but cleared after 30 seconds, i pulled over and the header tank was nearly empty but it did not seem to have overheated. I topped it up and drove the mile back to home, i left it running to see if i could find a leak but there was none, i walked round the back and there was white smoke coming out the exhaust. Would the head have warped? i have a spare if it has. Sorry for the long story. Any advice is most welcome. Have a good weekend.
Old Mar 13, 2010 | 04:50 PM
burnzy's Avatar
burnzy
burnzy
something is deffenitly wrong for a head gasket to go in 5k, i'm guess it's had h/g replaced not that long ago then it must of been warped from before the head that is, a ford one should be fine for a good 60-70k atleast, take the plugs out aswel if they look unusually clean it's been burning water, so it'll deffo be your h/g thats gone because the head isn't straight.
Old Mar 13, 2010 | 05:09 PM
tarry500's Avatar
tarry500
Thanks, i never thought that the head could have been warped in the first place. My girlfriends brother did the conversion for me but he gets a local garage to put new gaskets and a cam belt and general freshen up before he puts them in himself. He said that none of the other cars has had a head gasket go and is puzzled why, maybe you have hit the nail. We took the plugs out to try and do a compression test but the tester would not screw into the plug holes, all the plugs looked fine. Thanks for your help
Old Mar 13, 2010 | 05:33 PM
burnzy's Avatar
burnzy
burnzy
or the garage he's taken it too hasn't tightened it down properly could of just been a mistake if it's not happened before and easily done if in a rush, but more than likely be a warped head esp if you dont no the history of the engine before it came to your G/F brothers shop
JoeyBoyden
20
Aug 22, 2015 03:23 PM
220TC
13
Oct 25, 2004 11:22 PM
220TC
Oct 25, 2004 06:03 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
