Failed power sterring pump
Old Feb 26, 2010 | 12:23 PM
speedy101's Avatar
speedy101
Default Failed power sterring pump
I've had my ford focus for nearly three years now and the other day noticed a patch of fluid on the drive. Checked all the fluid levels and noticed the power steering fluid was low so topped it up went out for a drive and came back, checked under the car and noticed the fluid leaking again.
When I took the car into the garage the mechanic that looked at it said mine was the second focus in a week he had seen with exactly the same fault.
When he looked at my car he said there was also coolant in the spark plug bays
I wouldn't mind but the car has only done 34000 miles, I can't believe it power steering pump and has failed after not that many miles.
Got a quote from the garage and he said its going to cost nearly £600 to fix everything that is wrong
Has anyone else got a focus 1.6 on 05 plate I only had the spark plugs and washer jets replaced three months ago because they were leaking into the spark plug bays
Old Feb 26, 2010 | 03:50 PM
woolford's Avatar
woolford
never heard of coolant in spark plug bays
Old Feb 26, 2010 | 06:38 PM
cosworth726's Avatar
cosworth726
hi mate did my mates 05 16 c max only did 26000 miles had pump re conned cost 110 but when i refitted it could not stop it leaking from the pipe that goes in to pump found out a week later that ford had moddifed the pipe cost another 90 pound for a pas pipe then the two fanbelts are stretch fit needed ford belts that came with the tools to fit them WHAT A NIGHTMARE
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
jonfoc
16
Sep 11, 2018 05:35 PM
155lee
Oct 27, 2015 04:55 AM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
