Dashboard removal, where the best place to start?
Remove all the trim, glove-box, heater controls, ashtray panel, centre console, clocks. upper/lower column shrouds.
Steering wheel off, Column out. Pinch bolt where it joins the rack, then 2 nuts underneath and 2 nuts facing driver.
7 Torx bolts out. 2 each side and 3 along the top.
Support straps behind the Ashtray panel, 10mm nut behind the heater controls.
I think thats pretty much it, obviously disconnect wiring and plugs as you pull the dash forward. It's really not that hard. Hope I didn't forget anything.
By the way, I got my headliner out absolutely intact without removing any glass. I just took the visors out and the pillar trims where the seat belts are. Then just eased it out from behind the seals, using a flat bladed screwdriver and alot of care. Took about 30 mins.
i think the rear pods are riveted on so will be a case of drilling the rivets out try to fish the leftover bits of rivets out from where they land in the rear arches and sills as they will rust pretty quickly if left and probably take your sills with them eventually!
Surrey RSOC Photographer
Yes they are riveted on. No real worry bout fishing the bits out that fall down inside the rear quarter as the rivets should be aluminium so wont rust.
borboyous
Aug 22, 2015 11:17 AM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
